![]() | Home > Puma (Tdci) > Rushing fan noise under acceleration |
| Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 927
If it sounds like a mini hurricane then yes it's likely to be a hose. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
| whiteley5 Member Since: 06 Jun 2020 Location: London Posts: 5
I had something similar recently after hitting a pothole. It was a cracked inlet manifold.
| Packster82 Member Since: 15 Jul 2020 Location: Cirencester Posts: 24
I’m a bit out of my comfort zone on this as the leak isn’t obvious, will have to drop it in! I’ll update for everyone’s info but thanks for the input.
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363
Few things to check here - with reference pictures https://www.defender2.net/forum/topic61960.html > 110 XS Double Cab
| PCM Member Since: 25 Jan 2019 Location: North East Posts: 895
I had exactly the same issue and whooshing noise.
Drove it around for a few more days confused until the light came on and the vehicle lost power. Was a hole in one of the intercooler hoses. Replaced with silicone hoses. A real knuckly scraping job to do the lower elbow but ok to do. Loads on info on here if you fancy giving it a bash. |
| All times are GMT |
