![]() | Home > Puma (Tdci) > Rushing fan noise under acceleration |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926 ![]() ![]() ![]() |
If it sounds like a mini hurricane then yes it's likely to be a hose. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
whiteley5 Member Since: 06 Jun 2020 Location: London Posts: 5 ![]() ![]() ![]() |
I had something similar recently after hitting a pothole. It was a cracked inlet manifold.
Packster82 Member Since: 15 Jul 2020 Location: Cirencester Posts: 24 ![]() ![]() |
I’m a bit out of my comfort zone on this as the leak isn’t obvious, will have to drop it in! I’ll update for everyone’s info but thanks for the input.
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
Few things to check here - with reference pictures https://www.defender2.net/forum/topic61960.html > 110 XS Double Cab
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
I had exactly the same issue and whooshing noise.
Drove it around for a few more days confused until the light came on and the vehicle lost power. Was a hole in one of the intercooler hoses. Replaced with silicone hoses. A real knuckly scraping job to do the lower elbow but ok to do. Loads on info on here if you fancy giving it a bash. |
