Home > My Defender > Puma to LT1/8L90 Restomod
Page 6 of 41 <123 ... 567 ... 394041>
mikeh501
thanks, still not on the road as yet!
where theres that risk ive either gone with plastic washers or duralac or both sometimes. Thumbs Up
My tub was that bad in parts (like seat belt anchors) that I had to replace quite a lot of it with YRM parts which are over engineered with thicker metals so not expecting an issue too soon lol
Post #877014 8th Jan 2021 11:38am
mrfirepro
United Kingdom 1996 Defender 90 300 Tdi HT Bonatti Grey
Got everything off the inside bulkhead so that it could be removed
Got the engine, GB and TC out
Now back in the workshop ready to strip the final items.
Now thinking about galvanising the chassis, I'd really like to keep this chassis as it's in good codition and I'm mindful of the implications of a new chassis around DVLA.
Is it worth galvanising or better to buy a new one????
Post #877545 10th Jan 2021 6:30pm
mikeh501
If it’s in fairly decent condition it’s obviously better to get yours galvanised. You might struggle getting someone to do it. If you can collect all your stuff together then do it as a bigger job at the galvaniser that might be best.
Post #877547 10th Jan 2021 6:37pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
No reason not to galvanise the chassis you have, but be mindful that any good galvaniser will reject items with even the tiniest amount of paint/grease on them. I'd look into having the chassis chemically stripped to remove all contaminants from inside and out. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #877551 10th Jan 2021 6:42pm
mrfirepro wrote:
...I'm mindful of the implications of a new chassis around DVLA. ...
If it is a new chassis as opposed to one off another vehicle there should be no implications.
Post #877572 10th Jan 2021 7:32pm
JOW240725
You've made a great start!! As for galving... I'd say galv as much as possible!! James
Instagram @suffolk_rovers
Post #877634 10th Jan 2021 11:53pm
mata
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Hey Mr Fire Pro!
Just found your thread, fantastic stuff, your Lotus Carlton looks immaculate great work there. Also very jealous of your shed!
I've got an defender conversion underway with BMW M57 and ZF 8 speed auto, to be fair it's 'nearly finished'. If you have any questions regarding the ZF or anything else do drop me a line.
Keep up the good work!
Mat
Post #878642 15th Jan 2021 5:38pm
mrfirepro
You may have noticed a change in the title, After talking to various manufacturers/suppliers over the past few months, universally there have been questions over the technical viability of a T56 manual conversion (I know of only 1 that has been done).
The major challenge is making the adapter from the T56 to the LT230, even when suppliers say they can do it, they are probably not aware that the T56 is not 4WD compatible and the adapter though not impossible is a challenge. I know Rakeway have made one but as they will not return my calls or emails thus I’m guessing they are not that interested in making another.
The further challenge is that the T56 is 130mm longer that the standards autos used for the normal LS swap, so it's a bit of an unknown as to where everything is going to end up, particularly the gearstick and LT230.
Finally, a comment that has been made by nearly all, is that the manual will be less sympathetic to the drive train (I know it's how you drive it as well LOL) and that an auto will probably be more suitable.
I'm absolutely no expert and all I can go on are the comments I have received.
I've also changed to the more modern LT1 instead of the LS3 as I understand the LS3 is about to stop production. I'm also going for the 8-speed auto (8L90) in truck configuration where there are numerous available adapters.
This change is a little more costly, I'm hopeful it will be a smoother ride.
Thanks for the kind comments so far.
Post #878651 15th Jan 2021 6:05pm
Linds Hanson
I think you have made a wise choice with engine /trans the manual option always feels like a handful in a high powered Defender particularly under hard acceleration between gear changes. Handling and traction are much improved if the driveline remains loaded during gearchanges as it does with auto trans. I would recommend using a new Marsland galv chassis as these are galv from new and dont have any issues with rust and old paint inside the box sections. Chassis replacement would also remove any accident misalignment worries.
Post #878811 16th Jan 2021 2:36pm
mrfirepro
Been in touch with Karl at Marsland, just waiting for him to send me an invoice. I cant remember exactly what he called it but I'm getting their "Utility" chassis as it suited to the LT1 mounts which I can get from RW's in the states.
Got the chassis apart from the axles
Post #878830 16th Jan 2021 3:20pm
Likeomg
This is who I approached for the T56 conversion a while back... the price was £6k+.
Actually I just checked my email - £6,670 Whistle Big Cry
Post #878891 16th Jan 2021 5:37pm
mrfirepro
Quick Question
Before I butcher the steering lock is there a method for removing the steering column from the bulkhead.
Post #879478 19th Jan 2021 10:31am
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
You will need to drill out the fixing bolts for the ignition barrel/steering lock clamp. They are sheer bolts and you will need new ones to refit it. P/N QRH100030 1989 90 4.3 V8
2012 L405 OF
2014 D4 HSE Lux (SOLD)
2015 90 HT (SOLD)
@d9o.mf
Post #879483 19th Jan 2021 10:58am
Linds Hanson
The shear bolts can be knocked around with a sharp centre punch
Post #879559 19th Jan 2021 3:30pm
The Crab Botherer
United Kingdom 2001 Defender 90 Td5 ST Nato Green
L110CDL wrote:
So very grateful for the pic's Mrfirepro Bow down
When they first came out i wanted one so bad, but which ever way i tried, i just could not afford one Sad a very understated car Very Happy
Me too, totally love them, I hadn't seen one for years and years till about 5 years ago , when they were filming outside our house for "Reg" starring Tim Roth. The guy who was running security had parked his black one opposite our house...very nice motor
Post #879561 19th Jan 2021 3:34pm
