Home > My Defender > Dormobile Camper with a twist
Page 4 of 5 <12345>
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Upgraded the air intake with a 100mm inlet pipe fed from the wing top.
In situ measuring up to see what needs to be moved or adjusted...it's tight!
The pipe snags on the alternator bolt...a quick fix for now was to wrap the pipe in aluminium exhaust repair!
I did another wrap at the brake resevoir bracket as that rubs as well.
Fitted the pipe all in to the airbox
I also modded the airbox by removing the water trap and blades to open it up more and fitted a K&N filter.
My reasoning is although a 100mm intake pipe, with bends and such, i reackon an average of 85mm from the wing top to the air filter, unrestricted.
That gives me an area of 78cm2. If i fit a snow cowl to protect from water ingress into the pipework, this also has an opening of 78cm2.
The original air intake ducting is 47cm2.
I'm waiting on a replacement duct end jobby to finish it at the wing top, when that's done i'll post pictures.
In other news, i'm waiting on some more fuel pipe for the rear aux tank to be fitted.
Post #871707 6th Dec 2020 11:40pm
All good stuff except for the K&N filter. Some years ago, Pete Bell did some dyno tests of different filters and concluded that the OE paper one is the best of the bunch. Plus, the oil on K&N's, IGT's etc. have been known to gum up the MAF sensor. Darren
Post #871768 7th Dec 2020 11:37am
L110CDL
I had a piper cross air filter years ago and you had to put oil on it, it was a load rubbish and the difference when i put a K & N filter on was so much better, BUT i have never put any oil on the K & N filter's and find them breath better than the paper one's that i have tried Thumbs Up
This is my opinion and what i have personally found over the years with all my vehicle's Very Happy Clayton.
Keeper.
Post #871867 7th Dec 2020 10:24pm
Badger110
That's interesting to know about the K&N
I'll keep monitoring it for now and next time round look at an original if it's no different Thumbs Up
Post #871882 8th Dec 2020 12:12am
Badger110
Re jigged the pipe work now it’s fitted to the wingtop to stop it rubbing on the alternator bolt.
I drilled 2 holes in the arch plastic and run a jubilee clip through it to pull it tight to the wheel arch.
With the exhaust bandage it stops the duct being crushed .
Pic of the inside of the airbox with gubbins removed
What to do with the hole in the bottom... Question
Post #872146 9th Dec 2020 5:14pm
Badger110
I did finish the install of the tune and, to put it politely, it goes like Censored off a stick now.
Air intake upgraded to 100mm intake pipe from the wingtop including airbox mod
K&N filter
BAS intercooler
BAS silicone pipes
BAS Tune
EGR blank
De cat and mid box removed
From 1400RPM - 3000rpmish it pulls like a train
The pipe de cat and mid box didn't make much difference but it does sound abit more fruity now Razz
The only downside is i tend to become heavier on the right foot Whistle
Next job is timing chain replacement and i may drop the head off for valve cleaning as it's all full of Censored from the EGR and crankcase breather.
I have toyed with the turbo upgrade but it doesn't seem worth it other than maybe having further pull after 3200 rpm where mine starts to fall off the torque curve.
It's not a racing toy Laughing
Post #876694 6th Jan 2021 5:52pm
L110CDL
Good outcome in the end after all the work carried out under the bonnet Thumbs Up Clayton.
Keeper.
Post #876763 6th Jan 2021 10:14pm
Badger110
We had a moment on Friday and went shopping at the local paint shop....
There’s still lots to do at the rear end but the roof will be coming off to get it into the workshop for that part
Post #886927 21st Feb 2021 3:20pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
I could have sworn the doors I had off you were blue Paul? Laughing Loving the colour! what prompted the change? 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #886930 21st Feb 2021 3:31pm
Badger110
Indeed they were!
I have gone through several styles of 2nd row doors and finally went with some new ones from sp4x4 which required painting.
We were looking to change the colour from Buckingham Blue to something a little different and well, I think we’ve done that 😁
Post #887043 21st Feb 2021 10:59pm
gcc130
Certainly have! Very Happy
Post #887046 21st Feb 2021 11:31pm
L110CDL
No problem spotting you now Wink Clayton.
Keeper.
Post #887183 22nd Feb 2021 10:05pm
Badger110
Finally back together.
I still have the roof and rear cross member to spray but it was too cold ( but sunny! ) today
Post #888320 28th Feb 2021 6:37pm
L110CDL
Taking shape there now with the new colour, what colour are you going to be doing the wheels or are having different rims Question Clayton.
Keeper.
Post #888555 1st Mar 2021 10:19pm
Badger110
Still not sure on the wheels, wife wants Sawtooths, I want Blindos but I'm happy with the Wolf's, even if they sit inside the arch's Wink
As for colour, I'll go for satin black..I think green will make it look tacky Laughing Laughing
Post #888565 1st Mar 2021 11:00pm
Page 4 of 5 <12345>
