|  | Home > Off Topic > Girling brake master cyl... |
| htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 549    | Could be worth a call to Past parts in Bury St Edmunds, as they have a wealth of knowledge. | ||
|  22nd Nov 2020 6:19pm |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219      | Thanks, I'll give them a shout      | ||
|  22nd Nov 2020 6:23pm |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2553    | This may help https://lrxd.org/documents/lrxd/aesp/trail...ALOGUE.pdf
 Page 70. Last edited by Ianh on 22nd Nov 2020 8:54pm. Edited 1 time in total | ||
|  22nd Nov 2020 8:46pm |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219      | Thanks,  I've already got all  the manuals for the trailer and  the parts I'm after aren't shown
 If you look at chap 2-2-3 page 4 or 6 (same diagram on both) it's the fittings to hold together parts 29 & 24 that I'm after. | ||
|  22nd Nov 2020 8:53pm |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2553    | Did you manage to locate the missing fixings and washers etc ? Always handy to know what they are if I ever need some for my penman.
 Weird how they are not labelled on the diagrams or lists given the huge detail they go into on everything else | ||
|  9th Dec 2020 6:06pm |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219      | Yes I bought a generic 0.75" cylinder off of ebay.
 with htb2's advice I contacted past parts. They were most useful, had the reservoir cap and the bolt thing in stock (cap was £20 mind! although I knew they were expensive) The bolt and rubber seal kit was about £6 Just got to fit it now, and get a new goodrich hose made up. I also bought a replecement (from somewhere else) plug to fit the indicator light. Looks like an econoseal but better (made by durite), I'll post all the part numbers up later. Was also working at a site today, and the chap had a Mk3 sankey. which had the rare spare wheel carrier on it. So I took plenty of photos and got every dimension off of it; Think I'll be knocking one up for the penman. | ||
|  9th Dec 2020 7:38pm |
| Posting Rules
