![]() | Home > In Car Electronics (L663) > Dash display lighting |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3490 ![]() ![]() |
Try the interior illumination switch, which is down by the park brake.
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Thanks J,
I asked on another group and was told to bend down a bit further! It’s not exactly obvious and you have to press it in and when it pops out turn it to adjust! ![]() 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
![]() It seems a bit out of the way. |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 ![]() ![]() |
Did it fix the issue?
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 ![]() ![]() |
This illumination switch is not fitted to my Defender, I was convinced all the time.
Took a look again today. Magically it appeared... 😳 Last edited by Sepp on 21st Nov 2020 10:05am. Edited 1 time in total |
Good morning Simon- I haven’t tested it yet, if it’s dark enough later today to trigger dusk/ night lighting I’ll give it a go. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Simon, it works in daylight but ............. it seems to have a fair bit of lag between turning the knob and dimming/ brightening happening. I’ll look after sunset again because I think that it was already on maximum brightness and that was really too dark even at night to see the info/sat nav screen between the dials. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
c4skp Member Since: 11 Oct 2020 Location: Dorset Posts: 25 ![]() ![]() |
I have the same issue.
On a dark day, everything is very dim. The control dial is on maximum. Has been like it since new, so may be a dealer fix. Is the lux sensor in the centre front of dash? |
Philm Member Since: 19 Jun 2020 Location: Manchester Posts: 182 ![]() ![]() |
Mine is now working correctly after 2.0.6 update.
I now have both screens dim at the same time but the brilliance control has very little effect. I can see a tiny change in intensity but it’s still too dark to read at dusk after the screens have dimmed. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
You still have your sun glasses on?
![]() Any chance you you post some photos? |
When it's dark
![]() Tried it again, back to not working ![]() Last edited by Philm on 16th Dec 2020 5:29pm. Edited 1 time in total |
Odd, the digital dash in my Velar has a black background and I’ve no issues viewing that at night. I would’ve thought the Defenders dash being blue would be more visible.
It’s not the dials but the info screen in the middle that is the issue
Thus is minimum brightness ![]() Click image to enlarge On Maximum ![]() Click image to enlarge Text is just as bad Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
