Home > In Car Electronics (L663) > Dash display lighting
Tim in Scotland
I haven’t done much dusk/dark driving but yesterday I found in the gloom of a winter’s dusk I could hardly see the dials and info display in the main dash display but the PiviPro display in the middle of the dash was still on daylight intensity (which was fine) so I went searching around the dash trying to find the lighting rheostat........... nothing found. So how do I change the intensity if the screen brilliance on the dash in front if the driver? I know where to adjust the PiviPro screen intensity. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #868619 20th Nov 2020 5:41pm
J77
Try the interior illumination switch, which is down by the park brake.
Post #868623 20th Nov 2020 5:58pm
Tim in Scotland
Thanks J,
I asked on another group and was told to bend down a bit further! It’s not exactly obvious and you have to press it in and when it pops out turn it to adjust!
Post #868638 20th Nov 2020 6:44pm
J77
Thumbs Up
It seems a bit out of the way.
Post #868652 20th Nov 2020 7:22pm
Simon Audi
Did it fix the issue?
Post #868686 20th Nov 2020 9:38pm
Sepp
Germany
This illumination switch is not fitted to my Defender, I was convinced all the time.
Took a look again today. Magically it appeared...
Post #868712 21st Nov 2020 7:26am
Tim in Scotland
Good morning Simon- I haven’t tested it yet, if it’s dark enough later today to trigger dusk/ night lighting I’ll give it a go. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #868736 21st Nov 2020 9:55am
Tim in Scotland
Simon, it works in daylight but ............. it seems to have a fair bit of lag between turning the knob and dimming/ brightening happening. I’ll look after sunset again because I think that it was already on maximum brightness and that was really too dark even at night to see the info/sat nav screen between the dials. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #868758 21st Nov 2020 12:39pm
c4skp
I have the same issue.
On a dark day, everything is very dim.
The control dial is on maximum.
Has been like it since new, so may be a dealer fix.
Is the lux sensor in the centre front of dash?
Post #868846 21st Nov 2020 8:34pm
Philm
Mine is now working correctly after 2.0.6 update.
Post #872845 14th Dec 2020 1:08pm
Tim in Scotland
I now have both screens dim at the same time but the brilliance control has very little effect. I can see a tiny change in intensity but it’s still too dark to read at dusk after the screens have dimmed. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #872850 14th Dec 2020 1:16pm
Simon Audi
You still have your sun glasses on? Smile
Any chance you you post some photos?
Post #872851 14th Dec 2020 1:19pm
Philm
When it's dark Thumbs Up
Tried it again, back to not working Big Cry
Post #872852 14th Dec 2020 1:27pm
J77
Odd, the digital dash in my Velar has a black background and I’ve no issues viewing that at night. I would’ve thought the Defenders dash being blue would be more visible.
Post #872886 14th Dec 2020 4:55pm
Tim in Scotland
It’s not the dials but the info screen in the middle that is the issue
Thus is minimum brightness
On Maximum
Text is just as bad Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #872906 14th Dec 2020 6:35pm
