![]() | Home > My Defender > hanks Double Cab |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2325 ![]() ![]() ![]() |
Chuff at idle yeah. Opened the oil cap and it puffed oil spots all over the underside of the bonnet > 110 XS Double Cab
Useful little addition. Had previously been using a cigarette lighter USB adaptor but found it caused DAB reception interference
![]() Click image to enlarge > 110 XS Double Cab |
Focal ES100K components fitted. Really pleased with the improved clarity!! But think a sub is needed as 10cm drivers struggle to provide volume or low end
![]() Click image to enlarge ![]() Click image to enlarge Went into the woods to scavenge some oak for a friends smoker ![]() Click image to enlarge ![]() Click image to enlarge > 110 XS Double Cab |
The grey vinyl interior panels are in the process of going black. Modern vehicles tend to have dark headliners and as the dash, seats, carpets etc are black I thought why not. Currently waiting on more cans of dye to complete and refit.
It's a fairly slow process as you have to go easy and build the layers up bit by bit. If you go too thick you end up with a glossy patch. So far so good, the two big headlining panels need another couple of coats as they are still a bit patchy but the little panels look great! ![]() Click image to enlarge ![]() Click image to enlarge > 110 XS Double Cab Last edited by hank on 24th Nov 2020 8:50pm. Edited 1 time in total |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 868 ![]() ![]() ![]() |
Dark headlinings and trim make a big difference IMO, I'm sure you'e aware but you can get black/grey fir tree clips too.
![]() Series 2 109" Series 1 80" |
Yes I ordered a bunch of black for trees to complete the job
![]() I left the vinyl on the panel and dyed straight onto it after giving the panels a bath, a sit in front of the log burner and a wipe over with acetone... Acetone seems to almost melt the vinyl though so if anybody does this don’t go too heavy on the acetone! Mrs hank was really pleased ![]() ![]() Click image to enlarge > 110 XS Double Cab |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1888 ![]() ![]() |
Wanting Focal speakers / tweeters and they look great
![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
Additional spray cans arrived yesterday so I built up some more coats... The final finish is honestly better than I had hoped for! Very very pleased with how it has turned out. Time will tell on longevity but initial indications suggest the black is quite hard wearing.
Refitted the panels this afternoon but it was dark by the time I finished so completed photos to follow... Just need to work out what to do with the sun visors ![]() ![]() Click image to enlarge ![]() Click image to enlarge > 110 XS Double Cab |
B pillar trims and sun visors to complete...
![]() Click image to enlarge ![]() Click image to enlarge and a 'before' photo ![]() Click image to enlarge > 110 XS Double Cab |
Another good job done this evening, fitting the gear selector assembly LR052893 bushes in an effort to make the gear shift that little bit more positive.
I followed MartinK’s guide linked below... Only difference being I managed to remove all four bolts without needing to remove the plastic transmission tunnel cowl using a knuckle joint on the socket. I also fitted four bushes rather than just two for a belt and braces approach. https://www.defender2.net/forum/topic29132.html Initially impressions are that the change into second and third is definitely better. Well worth the two quid and hours work! ![]() Click image to enlarge > 110 XS Double Cab |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8244 ![]() ![]() ![]() |
^^^ i have just done this mod. i fitted two as intended it may no odds on mine. so removed them and then fitted all four but upside down so they lifted the selector housing slightly. Much better after that. its was all tight clamped down before. Cheers
Focal ibus 2.1 sub fitted yesterday. Original plan was to fit it under the cubby in a mud uk sub locker which I had purchased ready for the job.
Got into fitting but just couldn't get on with the cubby on top of the locker as I found it too high. So on to plan b which was a lot more work but a much better outcome for me personally. Annoyingly the space between the second row seat striker brackets was too narrow by about 5mm so we slotted the bolt holes by a few mm either side to allow them to shift outwards slightly and provide clearance to accommodate the ibus 2.1 in between. The speaker signal wiring looks a bit messy in the photos but has since been tidied similar to the power wiring so it now goes out through the floor via a grommet, inside conduit externally and back inside at the rear of the seat box. The sound now is incredible! The components provided good clarity and top end but still the system was lacking mid and low range as well as volume. I'm big into music and audio so this is something that has been lacking in my Defender from day one so very very happy with the result A bonus that I was not expecting is that the front component speakers sound even better amped via the ibus 2.1 than they did amped through the Alpine head unit. I don't really understand why or how but this arrangement has taken the front component speakers to the next level! Even with the sub turned off. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge and a pic of the (now surplus) mud uk sub locker ![]() Click image to enlarge > 110 XS Double Cab |
Tonser Member Since: 08 May 2020 Location: Surrey Posts: 77 ![]() ![]() |
Well done Hank ! Looks great in ther and well worth the extra work. Glad to hear the sound is much improved, I’ll be installing the same over the Christmas break 👍
Hi Hank
Was the harness that came with the iBus long enough with the rear seat location or did you have to extend it ? You mentioned running the wires externally in conduit ... where did you bring them back in to connect to the head unit ? Thanks Tony |
