![]() | Home > Puma (Tdci) > Help some low life has tried to steal my 130!! |
Andy RV Member Since: 26 Apr 2014 Location: Somewhere Posts: 66 ![]() ![]() |
If you set your alarm off do you get just the horns or a siren as well? My understanding of it is if you can hear a siren you’ve got a BBUS.
I don't think that's right. I'm sure that the BBUS only sounds if the battery is disconnected (or flat).
The most definite way to check for the presence of a BBUS is to disconnect the battery without following the procedure to disarm the BBUS. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
1. set your alarm off you get the horns a BBUS
2. BBUS sounds if the main starting battery is disconnected (or its voltage drops below set point ). |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 588 ![]() ![]() ![]() |
Have you ever been thinking about a pedal lock ![]() Click image to enlarge https://www.shirefabrications.com/safe-tpe...to-fit-rhd In the evening I install it in my truck - and I'm quite sure I'm gonna hear them grinding this 4 mm steel plate down next to my bedroom ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
Sadly not if they tow it away first.
Tomotomo Member Since: 13 Feb 2018 Location: Bucks Posts: 71 ![]() ![]() |
I think I am going to fit the optimill removable steering wheel and swivel lock looks to be one of the best prevention mods. I now dont think I ever had a bbus so I would like to install something that does the same job.
Yes, if he manages to loosen my handbrake. It's 4 wheels locked ![]() ![]() Click image to enlarge |
You really don't want to know how easy that is to do.
