Home > Td5 > Engine vibrating
Page 3 of 3 <123
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
I hate to state the obvious, but that bill suggests they do not really understand/know what they are doing - just parts swapping (at a hell of a premium!). Rgds.
Chris
Post #861006 11th Oct 2020 6:18pm
mustafasoleiman
United Kingdom 2003 Defender 90 Td5 XS CSW Indus Silver
OK got the car back and the problem is solved. I attach the invoice of the work done (keep in mind that they also performed a service).
The only issue following this repair is the steering wheel being heavy on return when turning and the breaks feeling different... I may just get used to it or give them a ring tomorrow.
Alex
 http://instagram.com/h4vou/
Post #862282 18th Oct 2020 5:39pm
lightning
lf they've replaced the "ball joints" (l assume they mean the swivel balls) then the steering will most likely feel a bit stiff compared to how it was before.
That's because the swivels are supposed to have a preload on them and it's often zero on a Defender where it's not been checked for years.
And again, the brakes will feel different if they've replaced any parts. So long as the pedal isn't spongy and it pulls the Land Rover up straight then they are likely OK.
Post #862288 18th Oct 2020 6:08pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Normally shock absorbers replaced in pairs
And please change the 4 tyres from there recommendation if they are 20 years old they are well past there best
Glad shake is gone, could of been from a number of places looking at the bill. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #862293 18th Oct 2020 6:47pm
roel
Does the stearing wheel come back to straight ahead position by it's own or not? If not something is to tight.
Drive belt? I think they mean ancillary belt.
Only 1 oil filter? A td5 has an oil filter and an centrifugal filter. I would ask if they replaced both.
But nearly 20 years old tires on a 17 year old Land Rover? Age is not my main concern but by that age you will probably see cracks in the rubber near the rim and in the profile off the tires, that is not good. Because off the cracks you get stress points in the structure off the tire.
Further: your Landy is about new now. Twisted Evil Roel
2003 90 Td5 (2009-now)
Post #862421 19th Oct 2020 1:32pm
mustafasoleiman
Do these look bad?
If they do: any suggestions on what to replace them with and where to get them and how much?
Many thanks
Alex
Post #862569 20th Oct 2020 10:42am
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
If they’re 20 years old, replace them.
Don’t get TR’s again , they’re rubbish off road, and in snow, and not great on road either. 👍🏻 2002 td5 90 county hardtop
Post #862675 20th Oct 2020 8:50pm
mustafasoleiman
Any suggestions?
Alex http://instagram.com/h4vou/
Post #862765 21st Oct 2020 9:51am
The problem with tyres is that you're likely to get as many recommendations as there are tyre types. My current favourite is the General Grabber AT3 as it's quiet on the road and is winter rated, so will be good in snow and ice. Lots of folks favour the current BFG AT, although there have been quite a few questioning its performance in the wet. The OEM fitted Continental Crosstrac has a good reputation and many are pleased with the AT offering from Cooper. You pay your money and take your choice, really. Darren
Post #862770 21st Oct 2020 10:06am
jst
Free engine mounts then?
Whats a cabin filter?
In lieu of comeback to fault finding questions, I guess engine mounts at fault. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #863727 26th Oct 2020 11:20pm
mustafasoleiman
I think it was the UJ... http://instagram.com/h4vou/
Post #863772 27th Oct 2020 11:13am
jst
thats wouldnt make the engine vibrate, thread title is engine vibrating
that would make the whole vehicle vibrate at speed.
i was annoyed earlier as i try to help people diagnose problems.
alot come on here, post the problem, then when asked some questions, never answer them. such as this thread.
its hard to remote diagnose when people dont answer the questions, sort of asks the question why bother with the post.
and i did mention the timing here :
jst wrote:
is this the service they did and it started vibrating after that. they have been in on timing then.
you need to find a better priced garage, panard rod is about £40 not £160, likewise rear trailing arms, for two examples.
in response to this:
mustafasoleiman wrote:
What are you second guessing sorry? You never mentioned "Tensioner-timing belt"
just to put the record straight.
So yes i was trying to help in response to your post. i posed a few questions never had answers, got annoyed, you then replied, i asked a load more questions then nothing back again.
But none the less you have it fixed which is good news and the garage must be delighted as must you.
do you really want suggestions on tyres or just asking to waste a bit more time? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #863872 27th Oct 2020 6:40pm
mustafasoleiman
You better ignore me... Thanks for your help.
A http://instagram.com/h4vou/
Post #863873 27th Oct 2020 6:46pm
jst
No problem will do as you request. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #863904 27th Oct 2020 8:52pm
Page 3 of 3 <123
