![]() | Home > Td5 > Engine vibrating |
mustafasoleiman Member Since: 21 Jun 2016 Location: London Posts: 108 ![]() ![]() ![]() |
Hello
I had my defender TD5 recently serviced and now when I drive above 50mph on the highway the engine becomes very rough sending vibrations throughout the car... If I let the gas go the vibrations stop so I don't thing is the tyres or the body causing it. The vibrations diminish when going above 65/70mph... It's like the pistons are not balanced properly... Any ideas? Any speed in town is fine. Thank you for any advice. Alex http://instagram.com/h4vou/ |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 688 ![]() ![]() |
What was serviced?
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
Are you sure its the engine? My gearbox vibrates for some reason around 3,000 rpm in 4th gear. 2005 Td5 90 XS
1989 V8 110 CSW |
Greasing the ujs on the props might have shown up a faulty one? Ray
theheffman Member Since: 21 Mar 2019 Location: bath Posts: 60 ![]() ![]() ![]() |
i have the same issue please see this post https://www.defender2.net/forum/topic73860.html not solved it yet. But i think its a UJ issue. |
back from the garage...
Description Unit price QTY Price Cartridge-engine oil filter 10.83 1 10.83 Rotor, 21.56 1 21.56 Element-filter 5.58 1 5.58 Element - Air Cleaner 14.8 1 14.8 Tensioner-timing belt 53.51 1 53.51 Belt-polyvee alternator 34.57 1 34.57 Pipe 111.44 1 111.44 Duct assembly-air cleaner/turbocharger induction system 71.07 1 71.07 Tank-radiator expansion 61.6 1 61.6 Damper assembly front 94.5 2 189 Damper assembly rear 85.89 2 171.78 Blade - Wiper 9.92 3 29.76 Kit-ball joint 42.28 1 42.28 Kit-ball joint 41.04 1 41.04 Disc-brake. 73.08 2 146.16 Set-pad front brake system 89.4 1 89.4 Disc-solid brake 78.5 2 157 Kit - Brake Lining 58.91 1 58.91 Gasket-differential housing to axle case 2.69 1 2.69 Grease 11.18 1 11.18 Bush-anti-roll bar 7.82 2 15.64 Joint-ball-lower arm front/rear suspension 53.37 2 106.74 Bush-anti-roll bar 3.9 2 7.8 Joint-propshaft universal 56.08 1 56.08 Reflector-rear 12.35 1 12.35 Rod-front suspension panhard 159.83 1 159.83 Arm - Rear Suspension 124.94 2 249.88 Bush-rear-lower arm rear suspension 12.16 2 24.32 Mounting-engine rubber 61.36 2 122.72 total 2,026.75 ![]() ![]() ![]() |
OMG... has this fixed the vibration
or was this the cause !
will soon tell... the car is still there... http://instagram.com/h4vou/
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8373 ![]() ![]() ![]() |
is this the service they did and it started vibrating after that. they have been in on timing then.
you need to find a better priced garage, panard rod is about £40 not £160, likewise rear trailing arms, for two examples. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 403 ![]() ![]() ![]() |
£56 for a u/j😧😧😧
Was this a main dealer? 2002 td5 90 county hardtop |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
Looks like a main dealer to me.
I’d say a failing UJ is the issue, but could be wrong. Best way is to take the props off and check. The greasing may well have increased the imbalance and showing it up. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
They are working on it this weekend... Hopefully Monday I will know... Expensive I know but the only place I know in west London that is not too far away. http://instagram.com/h4vou/
So this is what they did and then the vibrations started after this work, or it went in with vibrations and this is what they did to try and fix it? Cheers
