Home > Td5 > Engine vibrating
Page 1 of 3 123>
mustafasoleiman
United Kingdom 2003 Defender 90 Td5 XS CSW Indus Silver
Engine vibrating
Hello
I had my defender TD5 recently serviced and now when I drive above 50mph on the highway the engine becomes very rough sending vibrations throughout the car... If I let the gas go the vibrations stop so I don't thing is the tyres or the body causing it.
The vibrations diminish when going above 65/70mph... It's like the pistons are not balanced properly... Any ideas?
Any speed in town is fine.
Thank you for any advice.
Alex http://instagram.com/h4vou/
Post #859903 5th Oct 2020 3:08pm
Matt110
What was serviced?
Post #859905 5th Oct 2020 3:14pm
Is it a misfire? mine does it sometimes (dodgy connection on one of the injectors)
That makes it sound rough and vibrates... even stationary just revving it you can feel it.
Post #859919 5th Oct 2020 3:43pm
Hufflepuff
Are you sure its the engine? My gearbox vibrates for some reason around 3,000 rpm in 4th gear. 2005 Td5 90 XS
1989 V8 110 CSW
Post #859932 5th Oct 2020 4:33pm
mk1collector
Greasing the ujs on the props might have shown up a faulty one? Ray
My build thread
Post #859980 5th Oct 2020 8:23pm
theheffman
United Kingdom 2003 Defender 90 Td5 SW Cairns Blue
Re: Engine vibrating
mustafasoleiman wrote:
Hello
Alex
i have the same issue please see this post https://www.defender2.net/forum/topic73860.html not solved it yet. But i think its a UJ issue.
Post #860037 6th Oct 2020 9:24am
mustafasoleiman
back from the garage...
Description Unit price QTY Price
Cartridge-engine oil filter 10.83 1 10.83
Rotor, 21.56 1 21.56
Element-filter 5.58 1 5.58
Element - Air Cleaner 14.8 1 14.8
Tensioner-timing belt 53.51 1 53.51
Belt-polyvee alternator 34.57 1 34.57
Pipe 111.44 1 111.44
Duct assembly-air cleaner/turbocharger induction system 71.07 1 71.07
Tank-radiator expansion 61.6 1 61.6
Damper assembly front 94.5 2 189
Damper assembly rear 85.89 2 171.78
Blade - Wiper 9.92 3 29.76
Kit-ball joint 42.28 1 42.28
Kit-ball joint 41.04 1 41.04
Disc-brake. 73.08 2 146.16
Set-pad front brake system 89.4 1 89.4
Disc-solid brake 78.5 2 157
Kit - Brake Lining 58.91 1 58.91
Gasket-differential housing to axle case 2.69 1 2.69
Grease 11.18 1 11.18
Bush-anti-roll bar 7.82 2 15.64
Joint-ball-lower arm front/rear suspension 53.37 2 106.74
Bush-anti-roll bar 3.9 2 7.8
Joint-propshaft universal 56.08 1 56.08
Reflector-rear 12.35 1 12.35
Rod-front suspension panhard 159.83 1 159.83
Arm - Rear Suspension 124.94 2 249.88
Bush-rear-lower arm rear suspension 12.16 2 24.32
Mounting-engine rubber 61.36 2 122.72
total 2,026.75
Big Cry Big Cry Big Cry http://instagram.com/h4vou/
Post #860596 9th Oct 2020 10:35am
theheffman
OMG... has this fixed the vibration Bow down
Post #860601 9th Oct 2020 10:45am
theheffman
or was this the cause !
Post #860602 9th Oct 2020 10:45am
mustafasoleiman
will soon tell... the car is still there... http://instagram.com/h4vou/
Post #860603 9th Oct 2020 10:48am
jst
is this the service they did and it started vibrating after that. they have been in on timing then.
you need to find a better priced garage, panard rod is about £40 not £160, likewise rear trailing arms, for two examples. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #860615 9th Oct 2020 11:18am
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
£56 for a u/j😧😧😧
Was this a main dealer? 2002 td5 90 county hardtop
Post #860645 9th Oct 2020 2:10pm
Looks like a main dealer to me.
I’d say a failing UJ is the issue, but could be wrong. Best way is to take the props off and check.
The greasing may well have increased the imbalance and showing it up. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #860650 9th Oct 2020 2:32pm
mustafasoleiman
They are working on it this weekend... Hopefully Monday I will know... Expensive I know but the only place I know in west London that is not too far away. http://instagram.com/h4vou/
Post #860668 9th Oct 2020 4:38pm
jst
So this is what they did and then the vibrations started after this work, or it went in with vibrations and this is what they did to try and fix it? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #860672 9th Oct 2020 5:09pm
Page 1 of 3 123>
