Home > My Defender > Fuji 110 LS3 build
Page 20 of 65 <123 ... 192021 ... 636465>
grafty99
Cool 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #858434 27th Sep 2020 6:38pm
Procta
Looking good there! i do like the seats mind, do the bases come off these? if you need to get at the battery Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #858471 27th Sep 2020 9:19pm
mcma1
Fronts are Land Rover so pop off as normal. Rear are recaro factory but you just turn some threaded studs down that fit into the seat base frame so they can lift out too. Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #858476 27th Sep 2020 9:55pm
Pickles
It's all happening! looking forward to seeing more of your professional work.
Pickles.
Post #858489 28th Sep 2020 1:04am
mcma1
Thanks Pickles, made a start this evening on the cubby setup. I am using the gear lever this time and not the control box but not a fan of the chrome trim so carefully dismantled the assembly. Anyone any good methods to paint these chrome plated plastic pieces? Probably just going Matt or satin black from a can.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #858635 28th Sep 2020 9:52pm
grafty99
I'd start with 1000 grit wet. Any more coarse and you risk burring up the plastic.
The chrome layer will be pretty thin so you should be able to sand through it pretty easily, then just paint as normal with plastic primer and paint Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #858647 28th Sep 2020 10:57pm
JOW240725
Could wrap? James
Instagram @suffolk_rovers
Post #858661 29th Sep 2020 6:47am
mcma1
Post #858806 29th Sep 2020 7:04pm
mcma1
Thinking of just doing something simple like the Twisted cubby with 2 cup holders, also like the idea of the plate with the gear positions. Anyone suggest someone that could machine an alloy plate like this if I drew up the CAD?
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #858810 29th Sep 2020 7:19pm
Zed
mcma1 wrote:
Got sorted. Thumbs Up
Plastic chrome bits generally look cheap and wear badly. That looks much better.
Nice work. WARNING.
Post #858813 29th Sep 2020 7:24pm
Co1
I imagine anyone with a CNC mill could do you something. Try the guys at Retro Power though, I imagine they will be able to sort it or point you in the right direction. https://retropower.co.uk/
Post #858815 29th Sep 2020 7:29pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
You could try Falon Nameplates, the guys who do the Land Rover badges...
https://www.falon-nameplates.co.uk/ 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #858818 29th Sep 2020 7:48pm
mcma1
Post #858821 29th Sep 2020 7:52pm
db950
No problem, I’ll be contacting them shortly for a quote for a custom plate Thumbs Up
Love reading your build threads by the way, great stuff indeed. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #858825 29th Sep 2020 8:04pm
JOW240725
Fallon plates are good, had a few plates off them from LRO and will do custom. Otherwise I would have thought any decent engraver could do it. James
Post #858831 29th Sep 2020 8:24pm
