![]() | Home > My Defender > Fuji 110 LS3 build |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947 ![]() ![]() |
Fronts are Land Rover so pop off as normal. Rear are recaro factory but you just turn some threaded studs down that fit into the seat base frame so they can lift out too. Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3798 ![]() ![]() ![]() |
It's all happening! looking forward to seeing more of your professional work.
Pickles. |
Thanks Pickles, made a start this evening on the cubby setup. I am using the gear lever this time and not the control box but not a fan of the chrome trim so carefully dismantled the assembly. Anyone any good methods to paint these chrome plated plastic pieces? Probably just going Matt or satin black from a can.
![]() Click image to enlarge ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
I'd start with 1000 grit wet. Any more coarse and you risk burring up the plastic.
The chrome layer will be pretty thin so you should be able to sand through it pretty easily, then just paint as normal with plastic primer and paint ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7932 ![]() ![]() ![]() |
Could wrap? James
Got sorted.
![]() ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Thinking of just doing something simple like the Twisted cubby with 2 cup holders, also like the idea of the plate with the gear positions. Anyone suggest someone that could machine an alloy plate like this if I drew up the CAD?
![]() Click image to enlarge ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html Last edited by mcma1 on 29th Sep 2020 7:26pm. Edited 1 time in total |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
Plastic chrome bits generally look cheap and wear badly. That looks much better. Nice work. WARNING. This post may contain sarcasm. |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3768 ![]() ![]() ![]() |
I imagine anyone with a CNC mill could do you something. Try the guys at Retro Power though, I imagine they will be able to sort it or point you in the right direction. https://retropower.co.uk/ |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 570 ![]() ![]() ![]() |
You could try Falon Nameplates, the guys who do the Land Rover badges...
https://www.falon-nameplates.co.uk/ 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
Great contact ^^. Thanks for that. Andy
No problem, I’ll be contacting them shortly for a quote for a custom plate
![]() Love reading your build threads by the way, great stuff indeed. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
Fallon plates are good, had a few plates off them from LRO and will do custom. Otherwise I would have thought any decent engraver could do it. James
