Home > My Defender > 1997 Ex-MOD 110 restoration + Alu Cab pop top
Page 5 of 16 <123 456 ... 141516>
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
Bit more done,
Sump and engine mounts painted and fitted, new clutch in and engine fitted in the chassis.
Wheels have been blasted and last night covered them in tinted epoxy primer.
Tonight coated with fine finish Raptor in LR Willow Green.
 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #848071 4th Aug 2020 8:39pm
L110CDL
Good getting the engine on the chassis and those rims look nice as well Thumbs Up Clayton.
Keeper.
Post #848096 4th Aug 2020 9:37pm
Matt110
The fine finish raptor looks good. Haven't ever seen up close and been able to compare with the "normal" finish.
Is fine finish a specific type of raptor then or is it just done based on gun and pressure and feed rate?
Got quite a few bits that need doing in a similar finish but black.
Post #848109 4th Aug 2020 10:57pm
db950
Hi, thanks.
It’s just the standard Raptor but instead of using the Raptor gun (or Schultz gun) I use a gravity feed normal spray gun with 1.8mm tip @50psi.
The ratio I use for the tintable raptor is 3:1 (raptor:hardner) + 10% colour tint + 10% thinners, this gave quite a flat finish on the first coat so on the second coat I dropped to 5% thinners which gave the finish in the picture.
With black Raptor it would just be 3:1 + upto 10% thinners. Hope this helps Thumbs Up 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #848113 4th Aug 2020 11:27pm
Co1
Awesome looking work. Really enjoying seeing this come together.
Post #848124 5th Aug 2020 5:59am
Whirly90
England 1993 Defender 90 300 Tdi HT Keswick Green
Those wheels look great Thumbs Up I need to paint some wheels and have considered Raptor but using a Schultz gun would give a rougher finish than i want, now i've seen the finish you've achieved that's a decision made.
Post #848137 5th Aug 2020 7:37am
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
What a great thread!
I noticed you haven't used the washers circled here:
When bolting the swivels to the axle casing, is there a reason for this? I am led to believe they are hardened, presumably to spread the load over the softer (relatively) swivel ball. I could be wrong though.
 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #848140 5th Aug 2020 7:53am
db950
Thanks Thumbs Up
Whirly90 I’m not keen/not the look I’m after on the full Raptor finish with a Schultz gun either. This is a good compromise I think, took a few trials to get the mixture right but happy with it now!
Shroppy, good eye! These are something I still need to sort out, I’ll be removing them and fitting genuine LR bolts and washers I’ve got now. The bolts were ordered from Bearmach and while the originals have 14mm heads these bolts are 17mm head which give a larger footprint on the swivel and are easier to tighten with a larger spanner but I’d rather have the original bolts fitted I think. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #848156 5th Aug 2020 9:36am
db950
Gearbox and transfer box cleaned up, painted and fitted.
Now on with plumbing the engine up and painting the last few bits black and then onto the bodywork.
Also got a nice road trip on Sunday to pick up the Alu-Cab Icarus roof and ShadowAwn, just got to get the body built to put it on! 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #850023 14th Aug 2020 10:04pm
db950
Not much to see I know but very exciting to have these home ready to fit!
Post #850590 17th Aug 2020 8:08pm
Terryt
Excellent looking forward to the alucab bit ..looking to fit one ..
Post #850640 18th Aug 2020 7:32am
db950
Thank you. Can’t wait to get the roof on but lots to do first!
As an aside...it’s not normal practice to collect the roof and fit it yourself, they really do prefer to only having them fitted by an ‘approved’ fitter, mainly due to warranty purposes.
Got the fuel bled through and the engine started last night, raises moral slightly!!
Post #850658 18th Aug 2020 10:46am
s55shh
did fitting the alucab roof save you much on cost? Do they still take your old roof in exchange?
Post #850660 18th Aug 2020 10:53am
db950
Well, the cost of the roof is the same, fixed price non negotiable. Cost of fitting is on top of that of which I don’t know how much it would be, never asked.
They don’t take your old roof, I’ll keep mine in storage in case I ever want to convert it back or put the Alu-cab on to a different Defender. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #850662 18th Aug 2020 11:09am
Terryt
Thanks you for the info .. where did yours come from them direct or Uk supplies
Post #850739 18th Aug 2020 5:45pm
