Home > Td5 > what is missing here
davidblythe
Presume it is just a rubber plug but thought I would ask
and being really cheeky, a part no or a stockist Shocked
Post #829071 3rd May 2020 7:46pm
dorsetsmith
Its the hole for A/C pipe work
Part Number: 345140 but check has been long i may be wrong
Post #829076 3rd May 2020 7:55pm
htb2
Wales
Mine was missing as well. Two extra large penny washers a nut and bolt and sealer/hylomar job done. I used the body mount washers from classic range rovers or discovery as I had some
Post #829077 3rd May 2020 7:56pm
davidblythe
that was my next question, why is it there Thumbs Up
Post #829078 3rd May 2020 7:59pm
lightning
It’s to drain out water during heavy rain. After some discussion at Land Rover regarding where to put the drain hole, it was decided that up to three inches of water in the footwell was acceptable
Post #829152 4th May 2020 9:03am
roel
I thought that a flat floor and not working doorseals were good enough to get the water in while wading and out after rain. Mr. Green
On the Camel Trophy Discoveries there were cuts in the bottom off the doorseals to let the water in while wading other wise the disco's would float to long. Roel
2003 90 Td5 (2009-now)
Post #829155 4th May 2020 9:23am
