Home > Td5 > what is missing here |
davidblythe Member Since: 27 Apr 2019 Location: Cheam, Surrey Posts: 110 |
Presume it is just a rubber plug but thought I would ask
and being really cheeky, a part no or a stockist Click image to enlarge |
3rd May 2020 7:46pm |
htb2 Member Since: 02 Nov 2018 Location: aberdeenshire Posts: 509 |
Mine was missing as well. Two extra large penny washers a nut and bolt and sealer/hylomar job done. I used the body mount washers from classic range rovers or discovery as I had some
3rd May 2020 7:56pm |
that was my next question, why is it there |
3rd May 2020 7:59pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2244 |
It’s to drain out water during heavy rain. After some discussion at Land Rover regarding where to put the drain hole, it was decided that up to three inches of water in the footwell was acceptable
4th May 2020 9:03am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I thought that a flat floor and not working doorseals were good enough to get the water in while wading and out after rain.
On the Camel Trophy Discoveries there were cuts in the bottom off the doorseals to let the water in while wading other wise the disco's would float to long. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
4th May 2020 9:23am |
