![]() | Home > My Defender > Matilda The TD5 90 |
| Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5378
I like the stance! I would go for the black roof, as I think that will add that bit extra kick to the stance! or you could go full colour code.
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946
Nooo, don't go black roof
| TheMule Member Since: 08 Mar 2019 Location: Norfolk Posts: 41
Absolutely! I always question a decision long after making a change I think if it was to go any colour other than white it would be body coloured |
Don’t worry she won’t have a black roof, there are plenty of other things to sort out before I go painting bits! Have booked her in for a remap by empire tuning in April so I will update you all on the changes ! |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11096
I have been looking at a few 90's with the body coloured roofs and the body coloured roof is the way to go if you don't want the white roof
Absolutely Clayton, body coloured arches and roof, it will nearly be like grafty’s old colour scheme
Quick little job today fitting the Allisport Egr delete kit, fantastic quality and relatively easy to fit, in fact it took longer to remove all the black soot and gunk from my hands
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
Nice mod there but don't chuck away the egr and other bits
Still have it all so not a problem
Fitted the synchro gearboxes slickshift Monday , easy task just took a little drive to sort the bias springs out but what a difference it has made ! Would highly recommend it. I got mine with the new turret too because mine had worn badly and I thought it would be sensible to replace it whilst working on that area.
Great that the slickshift went all ok when fitted
Been studying the top pic above and had two thoughts A. Instead of painting the roof, leave it white and put a union jack on it B. Paint the rims white These are just my thoughts though 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219
I've been through a few manifolds on my Td5.. (it's remapped as well). In the end I took my spare one to a local engineering firm. Got it faced off and all the webbing milled out. Touch wood, it's been fine so far. "some say" that if you use an old already warped manifold, then they don't tend to warp anymore... time will tell, but so far, all quiet. |
| Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 732
There's a guy on eBay that sells skimmed and de-webbed versions on an exchange basis, I used him a couple of years ago and had no problems since. From memory it was about £70 after you got the refund for posting your warped one to him.
TheMule - the 90 looks great! 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
| All times are GMT |
