![]() | Home > Puma (Tdci) > Another Non Starter |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6728
Is the starter relay clicking under the driver's seat when you turn the key to start?
1988 90 Td5 NAS soft top
2015 D90 XS SW |
| JBLancs Member Since: 17 Oct 2019 Location: Lancashire Posts: 40
Can't hear anything I'll try with the seat out?
You probably won't with the seat in. You may need to put your finger on top and feel for it clicking.
See blackwolf's PDF for relay IDs. You will might be missing some (if non aircon/non ABS) but the tabs should show where these would have fitted. https://www.defender2.net/gallery/albums/u...Relays.pdf 1988 90 Td5 NAS soft top
2015 D90 XS SW |
The relay clicks when the ignition is turned, I have swapped it for a known good one and the problem persists.
Ignition turned on or when turned to start?
If ignition you’ve got your finger on the wrong relay (probably the “main” relay). If start then relay is working ok. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Looks like it could maybe be the ignition switch? But it is correctly cutting power to the radio etc at position 3? Could I try linking across the two terminals on the starter and see if it will spin up? What would be the best thing to do this with?
Sorry just seen your last message maybe it was the wrong relay, what colour wires come out of the starter relay?
Just been out for another look, I think that it was the main relay I could hear clicking when the key was turned and nothing from the starter relay. I've just had a go with another vehicle and you can hear the difference between the main relay clicking when ignition turned on and the starter relay when it fires up. I took the main relay out and I could hear the starter relay click I couldn't hear this on the vehicle which wont start.
So I can this morning confirm that the main relay clicks in but nothing on the starter relay. What does this suggest?
Cheers |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18038
First thought would be a loose connection on one of the relays, which is a very, very common Puma fault.
Wrote all the below and then thought... have you tried a different relay in case it has failed?
---- Get 6 inch+ length of reasonably fat wire. Turn the ignition on, make sure it's out of gear. Starter Feed Diagnosis:
Enable/Trigger Diagnosis:
If the ECU is immobilised This seems unlikely as it would not fuel the engine but you can tow/bump start it:
Basically, there are three things to try with your wire. Bridging the relay power terminals, manually enabling the relay, manually triggering it. Let me know how you get on. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Thanks Martin
That's exactly what I needed, I will work through it tomorrow. I have swapped the starter relay for a different one so would have thought that its okay? I'll report back once I've worked through your list. |
Click image to enlarge This is the setup I have under the drivers seat. |
Bagsy the 20p!
2015 D90 XS SW |
| All times are GMT |
