Home > Puma (Tdci) > Another Non Starter
JBLancs
England 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Another Non Starter
Land Rover Defender 2.4 TDCI 2009 model, will not start on the key. The fob works fine and operates the central locking the immobiliser light seems to do what it normally does but when the key is turned to the furthest position the starter does not spin. The blower and radio go off as per normal. I've swapped the starter today and have the same issue with a different starter. The vehicle can be bump started and drives and runs fine.
Sorry I know this has been covered plenty before, could someone point me in the right direction.
Post #821028 24th Mar 2020 7:28pm
Martin
Site Admin
Is the starter relay clicking under the driver's seat when you turn the key to start?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #821029 24th Mar 2020 7:32pm
JBLancs
Can't hear anything I'll try with the seat out?
Post #821032 24th Mar 2020 7:40pm
Martin
Site Admin
You probably won't with the seat in. You may need to put your finger on top and feel for it clicking.
See blackwolf's PDF for relay IDs. You will might be missing some (if non aircon/non ABS) but the tabs should show where these would have fitted.
https://www.defender2.net/gallery/albums/u...Relays.pdf  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #821034 24th Mar 2020 7:47pm
JBLancs
The relay clicks when the ignition is turned, I have swapped it for a known good one and the problem persists.
Post #821039 24th Mar 2020 8:06pm
Martin
Site Admin
Ignition turned on or when turned to start?
If ignition you’ve got your finger on the wrong relay (probably the “main” relay).
If start then relay is working ok.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #821046 24th Mar 2020 8:14pm
JBLancs
Looks like it could maybe be the ignition switch? But it is correctly cutting power to the radio etc at position 3? Could I try linking across the two terminals on the starter and see if it will spin up? What would be the best thing to do this with?
Post #821051 24th Mar 2020 8:31pm
JBLancs
Sorry just seen your last message maybe it was the wrong relay, what colour wires come out of the starter relay?
Post #821052 24th Mar 2020 8:32pm
JBLancs
Just been out for another look, I think that it was the main relay I could hear clicking when the key was turned and nothing from the starter relay. I've just had a go with another vehicle and you can hear the difference between the main relay clicking when ignition turned on and the starter relay when it fires up. I took the main relay out and I could hear the starter relay click I couldn't hear this on the vehicle which wont start.
Post #821054 24th Mar 2020 8:43pm
JBLancs
So I can this morning confirm that the main relay clicks in but nothing on the starter relay. What does this suggest?
Post #821155 25th Mar 2020 9:43am
First thought would be a loose connection on one of the relays, which is a very, very common Puma fault.
Post #821180 25th Mar 2020 11:02am
Martin
Site Admin
Wrote all the below and then thought... have you tried a different relay in case it has failed?
Get 6 inch+ length of reasonably fat wire.
Turn the ignition on, make sure it's out of gear.
Starter Feed Diagnosis:
  • Remove the starter relay from its socket, should be third from the back including empty tabs. Has brown/white, brown/red, black/orange, white/red wires.
  • With your wire, bridge the power terminals (with the brown/white and brown/red wires). If cranks and starts then the power wiring to the starter is OK, and the ECU is de-immobilised. So it's the trigger or enable not working (next stage).
  • If the starter turns and it does not start the ECU is immobilised (see immobilised section below).
  • If starter does not turn - faulty starter (you have changed this though) or wiring to it.
Enable/Trigger Diagnosis:
  • Keep or switch ignition back on.
  • Refit the relay and turn the socket over.
  • With your wire, from the wire side of the socket make a duplicate connection from a ground point (e.g. bolt holding the fuse box down) to the terminal with the black/orange wire. Now try and turn the key to start. If it cranks and starts, it's the enable line from the 10AS or engine ECU which is faulty.! If it cranks and does not start then the ECU is immobilised (see below).
  • If it does not turn, remove the temporary wire link.
  • Using your wire, again from the wire side fit one end alongside the white/red terminal.
  • Exclamation NOTE THIS SHOULD RUN THE STARTER. Touch the other end to the brown/white terminal. If it cranks and starts - it's the ignition switch or the wiring from it to the relay. If it cranks and does not start then the ECU is immobilised (see below).
If the ECU is immobilised
This seems unlikely as it would not fuel the engine but you can tow/bump start it:
  • Turn ignition off.
  • Remove the instrument pack plug and with a straightened paperclip bridge pins 3 and 4 in the plug and leave disconnected from the pack.
  • Now turn the ignition on and try to start with the key.
Basically, there are three things to try with your wire. Bridging the relay power terminals, manually enabling the relay, manually triggering it.
Let me know how you get on.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #821206 25th Mar 2020 1:12pm
JBLancs
Thanks Martin
That's exactly what I needed, I will work through it tomorrow. I have swapped the starter relay for a different one so would have thought that its okay?
I'll report back once I've worked through your list.
Post #821317 25th Mar 2020 9:50pm
JBLancs
This is the setup I have under the drivers seat.
Post #821330 25th Mar 2020 10:37pm
Martin
Site Admin
Bagsy the 20p!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #821342 25th Mar 2020 11:03pm
