![]() | Home > In Car Electronics > The definitive Defender ICE thread |
| CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1916
I have seen for sale an ex Defender SWE-1200 with LR plug but no control box or remote.
I am tempted to take a punt on it, but can anyone confirm that the original Defender item did not require the control box or remote? My truck has the Alpine CDE-133BT head unit so would this control the sub, even though not supplied from factory though with under cubby wiring, or am I barking up totally the wrong tree? Thanks. Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
So, I have done more research on here and thanks to K9F and others in this thread https://www.defender2.net/forum/topic5451.html?view=next it seems clear the OEM SWE-1200 has no controlller or remote and the the head unit will control the sub per the spec here https://www.alpine.co.uk/p/Products/SingleView/CDE-133BT
Think I might give it a whirl |
OK, so for those that are interested I ordered one of these, https://www.ebay.co.uk/itm/Alpine-8-Powere...2749.l2649 with some trepidation and it arrived today. Apparently they are out of new Defenders and the condition suggests that with just one small mark underneath. Backing plate to go in the cubby included. I haven't installed yet but feel it was a bit of a bargain and wanted to share. Apparently they have a few. Supplier might even be Twisted as it came from LR Automotive, Thirsk. Rob
| Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3363
LR Surplus is part of Twisted. The sub you bought was a take off part.
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044
Update from me, sadly due to work commitments my install is taking far, far longer than expected.
That being said, it has become a lot bigger and another box arrived today also. (No, I shall not disclose the content at this stage. ) Put up some of my old install like power wiring loom on eBay as well, as the old system whilst great spec has to be removed and replaced due to changes in the system. A one of a kind 4ga power feed with quality parts I took out, just the old and new install are different by far. It is a kind of kit as it fits in more or less easily as I did all the hard work getting everything just right. I have nearly everything I need for the new install, it’s just having the time free to get on with it. Click image to enlarge What is everyone else up to lately? ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| NineCherries Member Since: 10 Aug 2019 Location: Falkirk Posts: 59
Hello, I'm relatively new to defender ownership so I've been reading through this post bit by bit for speaker inspiration, so I hope no one objects to it being ressurected.
As of 2020, what speaker options are there on budget that are direct replacements, if possible, under the factory grills, without having to use spacers? My passenger side (2000 td5) has the wiper motor slap bang behind it and has scuppered all my budget plans. I have a set of vibe 10cm 2ways from my Jimny that I tried today but they are about 6mm too deep. And the 13cm components I had spare will need a larger spacer than I would like to use to come close. I'm trying to keep the look as close to standard as I can. There is a small spacer already fitted to the crappy 20 year-old paper cones that are there at present, drivers side in the pic to show the spacer. Thanks in advance for any suggestions. Tony. Click image to enlarge |
BarbelJim on here has 13cm speakers fitted, or at least did.
I think. (If I recall correctly!) that it was a TD5. I seem to remember that the hole needed a little cutting out away from the wiper motor area. But you have to be careful as it was quieter close to the edge. I am yet still working on my project, as I'm parked outside the weather is a big pain with getting things done but it's coming on. The reason it's taking so long is because it's pretty big, not physically big as such but a lot to it. With working as well, having free time is scarce even more so with a decent day without it raining. It's coming on very nicely though. ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808
Looking forward to see the install steve
2008 SVX 90 2000 XS TD5 90 |
Steve,
I've just noticed it's been nearly 8 years since you started the thread. To take that long it must be a seriously impressive system but bar a few cardboard boxes I can't see any photos. Unless I've missed them? Is it an audiophile or competition type setup? Can you post install photos or specs? WARNING. This post may contain sarcasm. |
I’ve had two systems since this thread was started, the original worked perfectly for many years. Then my HU was out of date the Kenwood and I thought about a re-fresh which is the second build now that I’m on.
It’s been around two years in the making, it’s taken longer than I envisaged due to import times last year waiting for parcels and having free time and decent weather to boot. Unfortunately we’ve had rain since August too, which pushed back my plans again and delayed and extra painting I could do as well. Let’s just say it isn’t what I’d say competition spec, but up there. 8+ speakers and 3x Amps and a lot of wiring involved that I am working on today. Brands are Pioneer, Kicker, Stinger, Xtronz and Knu Konceptz. 😈 No skimping on quality or expense spared. If I had access to a garage with space shielded from the weather conditions it would be a lot more rapid and easier to get on with but we can’t have it all. At least it comes with job satisfaction in the end. 😀 ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
We’re also lucky in the respect that Defenders, especially late models have high output Alternators as standard compared to many tidily little motors out there with Alt outputs of about 80A.
Although Class D Amp circuitry is very beneficial these days and with decided load on other electrical running gear like LED headlights these days and things are useful too. Although I wouldn’t likely be listening to music in the hours of darkness. 95% of the time I drive is in the daylight hours unless I have reason not to and have to be somewhere. Regarding the audio. I always find if you want quality and a big system the USA is the place where it is at. The range is improved, and although there is some the range of brands is massive and far less of the Chinese rubbish that can be very poor. The stuff we have here, or did have can be absolute rubbish. The few brands we have or did have that was good quality has ceased to exist due to Chinese junk flooding the market. For example, Kenwood no longer offer a 1DIN flip out HU Deck. A big no from me because people myself included like a choice. 2DIN doesn’t fit all vehicles without major mods either.. Proflex OFC cable has pretty much ceased availability. And instead there is a load of cheap jack CCA cable around. Always avoid CCA Copper Clad Aluminium Cable. You want Oxygen Free Copper, ideally Tinned too so TOFC. Usually in the specs. Very costly, but there is good reason why copper is used. It’s copper that is used in household installations too and that’s for good reason. Not Aluminium! The same applies with primary power cables, speaker wires and RCA cables although the latter do have sterling silver in conductors too. Again, costly but they are the best. The Land Rover loom is only fit speaker wires wise for its factory fit. Anything upgrade on that needs to be re-wired. I left the original loom in place obsolete and am adding a new loom in completely separate. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741
The best ICE without any doubt whatsoever is the soundtrack provided by a V8.
I find driving a Defender so involving that I cannot recall turning the radio on, for years. There is so much background noise from tyres, transmission, wind and other sources there is little point in spending any money on a sound system. It is not a Defender, it is a One_Ten |
I haven’t used my system now in what, it must be 3 years now.
Because it’s been taken apart, and being worked on etc. There is a lot of things Defenders are, and are not suitable for and we all have our likes and dislikes and different uses. The market was originally aimed at the rural market and farmers yet many people live in urban areas and their Defender has never been off of the beaten track. Noise issues can be combatted with soundproofing, but that doesn’t come for free or without work too. I think the Defender is an amazing multipurpose vehicle. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| All times are GMT |
