Home > Maintenance & Modifications > Transmission Noise - This could be expensive! |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2287 |
Hello Bluest
One approach if you can arrange it that may help, even get straight to the issue (or issues) is to find a good garage (Land Rover independent specialist would be ideal) get the Puma up off the ground on a lift so you can walk underneath it. The garage should also be able to lift the vehicle up on axle stands (the slide in type designed to work on the lift) this means that the Land Rover can be 'driven' rolling road like but in fresh air. If they are good, they will be able to roam around underneath and locate the area giving trouble... One word of caution...they should check... (you should check if there) that all tyres are stone free before they are spun up... I have done this twice once to confirm recently a wheel bearing and previously a universal prop shaft joint. Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
5th Nov 2019 6:56pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
Thanks X4. That’s probably the best approach, but am concerned that it won’t show up as it doesn’t happen at low temps. Even in the warm the car needs to on the motorway for 20 mins plus before it starts to make noises. I don’t have a trusted specialist either, which is a separate problem. 2007 110 TDCi Station Wagon XS
6th Nov 2019 9:15am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16876 |
Noises like this can be incredibly hard to track down, at least until something finally breaks.
From the description my immediate suspicion would be that you have a bearing breaking up in the gearbox. Do you notice any additional vibration through the gear lever when the noise is happening? |
6th Nov 2019 10:58am |
I haven’t noticed any additional vibes. 2007 110 TDCi Station Wagon XS
6th Nov 2019 1:21pm |
About this time last year my Disco2 (at 200k+ miles) started making a noise which matches your description almost exactly. Since it was impossible to track it down, I lived with it until earlier this year when, in the course of one journey, it suddenly became very much worse, quite alarming in fact, at which time the gear lever also started vibrating significantly whenever the noise was occurring - vibrating enough to be uncomfortable to hold. This confirmed my diagnosis of a bearing in the gearbox failing, and a replacement gearbox from a breaker has cured the problem.
I haven't yet stripped the old box to find out what has actually failed, but I suspect that the intermediate bearing on the mainshaft is breaking up. |
6th Nov 2019 2:34pm |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 131 |
I've had this type of noise twice, once a failing rear diff input bearing and once a seized UJ. On overrun it sounded like dropping a bag of bolts into a blender
Take one prop off drive it to see if it changes. Only appearing when warm could be due to treacle-like diff oil absorbing the noise. LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
6th Nov 2019 3:05pm |
Thanks Will. I will try that, although the need for hot weather for the issue to manifest may limit what I can detect. I may also just change all the UJs as a matter of course as I don't have any record of them being renewed in the past. There's no obvious play in them, but you never know.
Regarding the axles. Is there any way I can check the health of the input bearings, by checking play or end float or anything? 2007 110 TDCi Station Wagon XS |
6th Nov 2019 6:13pm |
Basically I put pressure on the diff flange in different directions whilst turning it to feel for roughness, but certainly you don't want there to be any movement of the flange up or down, side to side or in and out. LR Workshop
8th Nov 2019 3:57pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19572 |
It's worth being sure the diff nose pinion bolt / nut isn't loose too and no movements in the flange as mentioned I think above.
It sounds over simple but as with other things it can often be the smaller cheaper things. (Hopefully!) that are the culprits. Everything cheaper, and easy access is worth checking before delving deeper. And Prop UJ's and take they off the check as well, because they can be difficult to find a failed UJ too. It could be many things and there are plenty of ideas here given, some easy to check others not so butt start with the easiest and work your way though each ite. Sometimes the smallest thing can seem like a really big problem. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
8th Nov 2019 6:04pm |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 296 |
Maybe a quick squirt with a grease gun on the prop shaft yokes before you start removing prop shafts?
8th Nov 2019 7:00pm |
The UJ are all well greased, so I fairly sure it’s not that. 2007 110 TDCi Station Wagon XS
8th Nov 2019 8:37pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Have a ride over to Stonelake of Halifax they are a top team and do loads of Defenders
8th Nov 2019 8:49pm |
110willow Member Since: 22 Dec 2022 Location: Worcestershire Posts: 1 |
What was the outcome to this?
22nd Dec 2022 6:46pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3613 |
How old and what make are your tyres I had something like this, replaced the Tyres and it disappeared DEFENDER 90 TDCI XS,
23rd Dec 2022 7:31am |
