|  | Home > Maintenance & Modifications > Air Intake Mod |
| Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647      | Hi Blackwolf
 What’s the aluminium strip down the inner wing for ? Also what make of catch can is that , a mod I’d like to do ! Thank you https://www.instagram.com/hustynminepark/ | ||
|  26th Aug 2019 2:13pm |
| Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647      | Perfect , thank you . https://www.instagram.com/hustynminepark/ | ||
|  26th Aug 2019 2:22pm |
| BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 928      | Nugget Stuff do make a kit for the Td5 but, unlike for the Pumas, they don’t make an improved airbox. The thing I just cannot find (unless I buy the Nugget Stuff kit) is a wing inlet for a 102mm (or even 76mm) duct. And the chap who was going to make one for me has disappeared    Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders | ||
|  26th Aug 2019 3:06pm |
| bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239      | I could probably knock one up easy enough. Only issue is im hit and miss on free time so it wouldnt be a quick job.
 If interested send me a PM, of course a donation to the forum. | ||
|  26th Aug 2019 3:26pm |
| Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3362      |
 If I had a Td5 I'd get an Allisport air filter box. In fact I'm thinking of buying a Td5 just so I can have the Allisport air filter box! https://www.allisport.com/product-category...r-housing/ https://www.allisport.com/shop/performance...ipe-black/ Things of beauty. | ||
|  26th Aug 2019 7:07pm |
| PCM Member Since: 25 Jan 2019 Location: North East Posts: 895    | Wow. The nugget stuff and the Allsport seem beautiful, but not exactly a bargain.
 Is there a UK distributor or another supplier that does a similar kit. UK Don't have a snorkle, just want a better solution than chopping out the fan/plastic in the factory one. I'd have thought Alive or BAS would do one as it must help. | ||
|  29th Sep 2019 8:09pm |
| Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3362      | There are various generic motorsport airboxes that may fit a Td5 but none that I know of to fit a Puma. | ||
|  29th Sep 2019 8:15pm |
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123      | Nothing wrong with the standard Puma airbox. I’ve a 102mm pipe from airbox to wingtop. Covered by a snow cowl. Then a replacement airbox to turbo pipe in silicone. A vast improvement and the best non restrictive path you can get. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
 Instagram - @r22oyp Roy | ||
|  30th Sep 2019 1:11pm |
| 2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562      |
 I have the same set-up, water tight, from the top of the snorkel to engine. I also think it improves engine response too, but that could be just me justifying the cost to myself  | ||
|  30th Sep 2019 1:18pm |
| PCM Member Since: 25 Jan 2019 Location: North East Posts: 895    | Roy,
 I love your setup. I'd have just thought one of the manufacturers (mudstuff, Alive,BAS etc..) would have made this mod as a kit form. It'd be a big seller in my humble opinion. | ||
|  30th Sep 2019 1:33pm |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18057      |
 Personally I'm not a fan of the standard Puma airbox since it is awkwardly placed, has a fairly ineffective and significantly restrictive water separator, and the one way drain valves leak or fall out. With a bit of work and a decent aftermarket precleaner all but the first can be addressed, but, having gone down this route before opting for the Nugget filter, I know which I prefer. I can now see the state of my fully sealed filter just by opening the bonnet. | ||
|  30th Sep 2019 4:27pm |
| Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647      | The nugget kit does look the business , for now I’ve done as Roy and gone down the large intake pipe but when funds allow I will be purchasing the nugget .
 I find the biggest drawback other than the restrictive intake is changing the darn filter without breaking a plastic tab ! I absolutely agree that there must be a market for another manufacturer. I believe Pete at BAS did talk about it at one stage . https://www.instagram.com/hustynminepark/ | ||
|  30th Sep 2019 4:50pm |
| Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808      |
 Blimey that’s smart  I didn’t think I needed one but i do I do  but not at that price  2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 | ||
|  30th Sep 2019 5:18pm |
| Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3362      | You need one mate. It's so much nicer than that hateful Land Rover effort.
 Probably my favourite mod. Mine uses the side intake with their 90mm hose but I will fit the 102mm when I get a chance. | ||
|  30th Sep 2019 6:16pm |
| Posting Rules
