![]() | Home > Maintenance & Modifications > Air Intake Mod |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 ![]() ![]() ![]() |
Hi Blackwolf
What’s the aluminium strip down the inner wing for ? Also what make of catch can is that , a mod I’d like to do ! Thank you https://www.instagram.com/hustynminepark/ |
Perfect , thank you . https://www.instagram.com/hustynminepark/
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 924 ![]() ![]() ![]() |
Nugget Stuff do make a kit for the Td5 but, unlike for the Pumas, they don’t make an improved airbox. The thing I just cannot find (unless I buy the Nugget Stuff kit) is a wing inlet for a 102mm (or even 76mm) duct. And the chap who was going to make one for me has disappeared
![]() 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2225 ![]() ![]() ![]() |
I could probably knock one up easy enough. Only issue is im hit and miss on free time so it wouldnt be a quick job.
If interested send me a PM, of course a donation to the forum. |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
If I had a Td5 I'd get an Allisport air filter box. In fact I'm thinking of buying a Td5 just so I can have the Allisport air filter box! https://www.allisport.com/product-category...r-housing/ https://www.allisport.com/shop/performance...ipe-black/ Things of beauty. |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
Wow. The nugget stuff and the Allsport seem beautiful, but not exactly a bargain.
Is there a UK distributor or another supplier that does a similar kit. UK Don't have a snorkle, just want a better solution than chopping out the fan/plastic in the factory one. I'd have thought Alive or BAS would do one as it must help. |
There are various generic motorsport airboxes that may fit a Td5 but none that I know of to fit a Puma.
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Nothing wrong with the standard Puma airbox. I’ve a 102mm pipe from airbox to wingtop. Covered by a snow cowl. Then a replacement airbox to turbo pipe in silicone. A vast improvement and the best non restrictive path you can get. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 ![]() ![]() ![]() |
I have the same set-up, water tight, from the top of the snorkel to engine. I also think it improves engine response too, but that could be just me justifying the cost to myself ![]() |
Roy,
I love your setup. I'd have just thought one of the manufacturers (mudstuff, Alive,BAS etc..) would have made this mod as a kit form. It'd be a big seller in my humble opinion. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17916 ![]() ![]() ![]() |
Personally I'm not a fan of the standard Puma airbox since it is awkwardly placed, has a fairly ineffective and significantly restrictive water separator, and the one way drain valves leak or fall out. With a bit of work and a decent aftermarket precleaner all but the first can be addressed, but, having gone down this route before opting for the Nugget filter, I know which I prefer. I can now see the state of my fully sealed filter just by opening the bonnet. |
The nugget kit does look the business , for now I’ve done as Roy and gone down the large intake pipe but when funds allow I will be purchasing the nugget .
I find the biggest drawback other than the restrictive intake is changing the darn filter without breaking a plastic tab ! I absolutely agree that there must be a market for another manufacturer. I believe Pete at BAS did talk about it at one stage . https://www.instagram.com/hustynminepark/ |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Blimey that’s smart ![]() ![]() ![]() 2008 SVX 90 2000 XS TD5 90 |
You need one mate. It's so much nicer than that hateful Land Rover effort.
Probably my favourite mod. Mine uses the side intake with their 90mm hose but I will fit the 102mm when I get a chance. |
