Home > Maintenance & Modifications > Air Intake Mod
Page 2 of 3 <123>
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Hi Blackwolf
What’s the aluminium strip down the inner wing for ? Also what make of catch can is that , a mod I’d like to do !
Thank you https://www.instagram.com/hustynminepark/
Post #788686 26th Aug 2019 2:13pm
All the aluminium box does is provide a mount for the Provent 200, it picks up on the air filter bracket at the front and the intermediate wing support bracket at the rear. It also provides a convenient way to armour the bonnet release cable and radiator vent, which are now routed inside it.
Post #788691 26th Aug 2019 2:19pm
Bluericky
Post #788692 26th Aug 2019 2:22pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Nugget Stuff do make a kit for the Td5 but, unlike for the Pumas, they don’t make an improved airbox. The thing I just cannot find (unless I buy the Nugget Stuff kit) is a wing inlet for a 102mm (or even 76mm) duct. And the chap who was going to make one for me has disappeared Rolling Eyes Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #788698 26th Aug 2019 3:06pm
bankz5152
I could probably knock one up easy enough. Only issue is im hit and miss on free time so it wouldnt be a quick job.
If interested send me a PM, of course a donation to the forum.
Post #788703 26th Aug 2019 3:26pm
Zed
If I had a Td5 I'd get an Allisport air filter box.
In fact I'm thinking of buying a Td5 just so I can have the Allisport air filter box!
https://www.allisport.com/product-category...r-housing/
https://www.allisport.com/shop/performance...ipe-black/
Things of beauty.
Post #788731 26th Aug 2019 7:07pm
PCM
Wow. The nugget stuff and the Allsport seem beautiful, but not exactly a bargain.
Is there a UK distributor or another supplier that does a similar kit. UK
Don't have a snorkle, just want a better solution than chopping out the fan/plastic in the factory one.
I'd have thought Alive or BAS would do one as it must help.
Post #795890 29th Sep 2019 8:09pm
Zed
There are various generic motorsport airboxes that may fit a Td5 but none that I know of to fit a Puma.
Post #795894 29th Sep 2019 8:15pm
Roy5695
Nothing wrong with the standard Puma airbox. I’ve a 102mm pipe from airbox to wingtop. Covered by a snow cowl. Then a replacement airbox to turbo pipe in silicone. A vast improvement and the best non restrictive path you can get. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #796002 30th Sep 2019 1:11pm
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
blackwolf wrote:
The Nugget replacement filter with a proper large bore intake (Nugget, Nakatanenga, or similar) makes a verh marked difference. I thing the Nugget filter is TDCi only though.
I have the same set-up, water tight, from the top of the snorkel to engine. I also think it improves engine response too, but that could be just me justifying the cost to myself Thumbs Up
Post #796004 30th Sep 2019 1:18pm
PCM
Roy,
I love your setup. I'd have just thought one of the manufacturers (mudstuff, Alive,BAS etc..) would have made this mod as a kit form.
It'd be a big seller in my humble opinion.
Post #796006 30th Sep 2019 1:33pm
Personally I'm not a fan of the standard Puma airbox since it is awkwardly placed, has a fairly ineffective and significantly restrictive water separator, and the one way drain valves leak or fall out. With a bit of work and a decent aftermarket precleaner all but the first can be addressed, but, having gone down this route before opting for the Nugget filter, I know which I prefer.
I can now see the state of my fully sealed filter just by opening the bonnet.
Post #796026 30th Sep 2019 4:27pm
Bluericky
The nugget kit does look the business , for now I’ve done as Roy and gone down the large intake pipe but when funds allow I will be purchasing the nugget .
I find the biggest drawback other than the restrictive intake is changing the darn filter without breaking a plastic tab !
I absolutely agree that there must be a market for another manufacturer. I believe Pete at BAS did talk about it at one stage . https://www.instagram.com/hustynminepark/
Post #796032 30th Sep 2019 4:50pm
Sulisuli
Blimey that’s smart Thumbs Up I didn’t think I needed one but i do I do Big Cry but not at that price Rolling with laughter 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #796044 30th Sep 2019 5:18pm
Zed
You need one mate. It's so much nicer than that hateful Land Rover effort.
Probably my favourite mod. Mine uses the side intake with their 90mm hose but I will fit the 102mm when I get a chance.
Post #796056 30th Sep 2019 6:16pm
Page 2 of 3 <123>
