Home > Technical > LT230 Differential question
Page 1 of 3 123>
All the LT230 differentials that I have ever seen have looked like the photo below, and have 4 differential gears.
Recently however I have come across a new take-out centre diff unit that looks like this:
Clearly quite different, two diff gears only, and looking a bit "value engineered". Has anyone seen one like this before? Is it a later version/earlier version? Anyone know anything about it?
Thanks.
Post #774900 25th May 2019 6:12pm
MK
Thats news to me. Maybe cheaper to build.
Std design were prone to break the pins. At least have seen a couple. Puma 110" SW
Post #774945 25th May 2019 9:39pm
ibexman
Is that a 2 pin unit
Post #774947 25th May 2019 9:46pm
Yes, it's a two gear (single cross pin) centre diff. It has me puzzled because I'd never seen one before.
Post #774955 25th May 2019 10:32pm
ibexman
Not very strong then
Post #774970 25th May 2019 11:25pm
Apparently this type was used on the final production vehicles, which raises some interesting questions. Did JLR run out of normal diffs and get these made on the cheap, or were these a redesign to beef up the diff (with bigger gears) for the 70th V8 specials? The mystery deepens.
Post #775357 28th May 2019 9:51pm
MK
I imagine machining the 2 piece "usual" diff costs more than casting one piece. And I also imagine the new Defender does not come with the LT230 Question Puma 110" SW
Post #775365 28th May 2019 10:01pm
Caterham
I think the 70th editions come with the Ashcroft atb diff.
Post #775367 28th May 2019 10:05pm
excossack
I think the top one is an Ashcroft centre ATB 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #775397 29th May 2019 9:10am
No, the top one is a standard diff out of any standard LT230 transfer box (any except for ones with a diff like the lower one anyway).
Post #775443 29th May 2019 5:40pm
Naks
I agree with excossak, that top one is definitely not an LR one but an Ashcroft one --
Post #775464 29th May 2019 9:05pm
rallysteve
I assure you that the top one is a normal open differential for the LT230 as fitted to pretty much every LT230 (with the exception Blackwolf has noted) as stated by the OP.
From the LT230 manual:
 02' 110 TD5 Double Cab Rebuild Thread
Post #775471 29th May 2019 9:30pm
^^ agree
Post #775474 29th May 2019 9:43pm
There is no doubt whatsoever about the top one, the top one isn't in question. It's the second one that's the mystery.
Post #775482 29th May 2019 10:06pm
ashtrans
Site Sponsor
Hi,
the top one is stock used on most LT230's
the lower one is the very late TDCi stock open diff, open 2 pin design
used for approx last 2 years of production, major step backwards, making the weak link even weaker !!
I guess just a cost saving exercise, certainly not an improvement, Dave
Post #775524 30th May 2019 10:33am
Page 1 of 3 123>
