![]() | Home > Technical > LT230 Differential question |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512
Thats news to me. Maybe cheaper to build.
Std design were prone to break the pins. At least have seen a couple. Puma 110" SW ............................................................. Earth first. Other planets later |
| ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967
Is that a 2 pin unit
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18048
Yes, it's a two gear (single cross pin) centre diff. It has me puzzled because I'd never seen one before.
Not very strong then
Apparently this type was used on the final production vehicles, which raises some interesting questions. Did JLR run out of normal diffs and get these made on the cheap, or were these a redesign to beef up the diff (with bigger gears) for the 70th V8 specials? The mystery deepens.
I imagine machining the 2 piece "usual" diff costs more than casting one piece. And I also imagine the new Defender does not come with the LT230
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
I think the 70th editions come with the Ashcroft atb diff.
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
I think the top one is an Ashcroft centre ATB 1999 Defender TD5 110
No, the top one is a standard diff out of any standard LT230 transfer box (any except for ones with a diff like the lower one anyway).
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
I agree with excossak, that top one is definitely not an LR one but an Ashcroft one --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243
I assure you that the top one is a normal open differential for the LT230 as fitted to pretty much every LT230 (with the exception Blackwolf has noted) as stated by the OP.
From the LT230 manual: Click image to enlarge 02' 110 TD5 Double Cab Rebuild Thread |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
^^ agree
There is no doubt whatsoever about the top one, the top one isn't in question. It's the second one that's the mystery.
| ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 264
Hi,
the top one is stock used on most LT230's the lower one is the very late TDCi stock open diff, open 2 pin design used for approx last 2 years of production, major step backwards, making the weak link even weaker !! I guess just a cost saving exercise, certainly not an improvement, Dave |
| All times are GMT |
