Home > My Defender > My 1984 Ninety
Page 8 of 12 <123 ... 789 101112>
L110CDL
Great idea Bow down
No harm in having a good think about what to do with the diff lock, the answer will come to you Wink Clayton.
Keeper.
Post #774117 20th May 2019 8:49pm
JOW240725
That interior light bracket is ingenious! Bow down Possible not a big market but you could sell them. Peter6uk was looking for one recently on this thread https://www.defender2.net/forum/topic25956-15.html James
Instagram @suffolk_rovers
Post #774187 21st May 2019 8:59am
Martin
Site Admin
I'd have one too Mr. Green  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #774188 21st May 2019 9:00am
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Cheers fella's Very Happy
Unfortunately the 3D printer isn't mine otherwise I'd get cracking and quit the day job Laughing
I can enquire for others though. I'd need to check the later plastic type light is compatible, so if someone could measure the footprint of one I'll have a look. Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #774355 22nd May 2019 9:59am
L90Andy
Chapter 73 of non functioning diff lock;
Having determined the central pivot was the cause of most of the slack, I ended up with a nice 8mm shoulder bolt instead of the roll pin. I think when the roll pin was hammered through the assembly unless it was perfectly aligned it sheared off the internal part of the nylon bushes.
With the bushes now sitting nice and tight on the machined bearing surface of the shoulder bolt it appears to have finally resolved the issue Very Happy
Needs a road test to confirm, but at least the interior can go back in now. Instagram: L90andy
Post #777279 12th Jun 2019 8:31pm
L110CDL
Nice one Andy, hope the test run goes well Very Happy Clayton.
Keeper.
Post #777296 12th Jun 2019 9:20pm
L90Andy
Reassembly time! I managed to acquire a full set of early 90 County Brushwood(?) cloth seats a while ago and they've been stacked in the shed waiting for me to finish fiddling with the battery box/transmission. Luckily not there long enough for the mice to find them.
Got the fronts fitted last night, a good oem upgrade over the knackered black vinyl ones. Kinda like an 80's version of fitting the premium extended leather seats!
Also got a full set of mint period genuine waterproof seat covers to go on too so they will bring a bit of practicality back.
One little detail I noticed that I don't think is on the newer Defender seats; a three position adjustable sprung bar which alters the height of the front of the seat base. A nice feature, probably cost saved out on the later versions. No need mudrails now Thumbs Up
Not sure when I'll fit the rear seats as I'm going to make some rubber mats for the tub first. Instagram: L90andy
Post #777981 18th Jun 2019 11:10am
L110CDL
Nice that your putting in the middle seat and not a cubby box Thumbs Up Clayton.
Keeper.
Post #778047 18th Jun 2019 7:48pm
L90Andy
Yeah that was never in doubt, I have fond memories of my Dad taking me and my friends out in LR's he'd borrowed from work and remember thinking the middle seat was great to get so close to the action. Hope my offspring see it that way too!
Got it out the garage for a test run now the transmission bits and interior are all back together. Good and bad news, low to high now works beautifully and being able to use low for getting back into the garage is great. Bad news is the diff lock still doesn't work properly, although at least the new switch means the dash is telling me its stuck on now! Power donuts on our gravel drive didn't help to unlock it. Big Cry
I'll worry about that some other time, there are other jobs I want to get on with, namely sorting out the front end.
I planned to replace the cracked grille and headlight surrounds, but soon discovered another 'early 90' quirk - the headlight surrounds can be removed without taking the side & indicator lights off!
So looks like I'll have to tart up the ones I've got as never seen this type for sale anywhere. I've heard boot polish is a good idea. Any tips gratefully received.
New grille is easy though, anyone got one lying about!?
Next steps; bumper and grille surround off, flap disk and paint all accessible chassis. Instagram: L90andy
Post #780134 4th Jul 2019 11:52am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Andy, can you not enlarge the side light/indicator holes in the later surrounds? 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #780155 4th Jul 2019 2:56pm
G4UJS
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
I tarted up my Head Lamp surrounds, radiator grill and snorkel using Teak/furniture oil...... works well and last reasonably well.
Saw it on YouTube of course!!!
Rob
Post #780165 4th Jul 2019 3:57pm
L90Andy
Got the grille surround and bumper off without much of a fight. Pleasantly surprised by the dumb irons as they were solid enough with only the beginnings of flakiness.
I flap-disked everything in the immediate area and got a liberal coating of buzzweld all over it. I plan to do this on every bit of chassis, so eventually it will all get a coat, bit like the Forth Bridge Laughing
I procured a new grille as the old one was snapped in several places including the fixing holes.
When it came to restoring the headlight surrounds I jumped in confident the boot polish idea would work. It didn't.
Here is a comparison taken 5 minutes after I did the RH one and it was already fading. Looking at it 15 minutes later it looked the same as the LH one Big Cry I guess the plastic absorbed all the colour!?
Might try a few more coats, then try G4UJS's suggestion of Teak polish. Really don't want to buy new ones as these early ones aren't available anymore.
Thanks Instagram: L90andy
Post #785169 6th Aug 2019 9:04am
G4UJS
Furniture oil not polish Andy Thumbs Up
Post #785190 6th Aug 2019 10:56am
excossack
Spray paint them ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #785193 6th Aug 2019 11:12am
L90Andy
Embarassed Cheers Rob!
Paint will be a last resort, was a case of trying (free) things close to hand, hence the boot polish idea first. Instagram: L90andy
Post #785207 6th Aug 2019 12:45pm
