Home > Maintenance & Modifications > Rear Half Shaft Replacement
Page 2 of 9 <123456789>
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
I fitted the Britpart one piece shafts a couple of weeks ago , time will tell but they are doing the job at the mo and they’re really pretty good value .
One thing to point out is that they’re shipped unpainted so I etch primed , primed and sprayed them satin black.
Another member put a pic up having not painted them and they were pretty ugly with the surface rust . https://www.instagram.com/hustynminepark/
Post #761478 2nd Mar 2019 2:21am
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Thanks for all the advice & help.
I was pleasantly surprised to find that the job was easy & quick as everyone had suggested.
A couple of hours including finding the various tools and coffee breaks. Very Happy
There's still some slack when I ty to turn a back wheel (with diff lock & handbrake on) but not so much as before. I'm not sure tbh what's normal?
I'll take it for a test drive & see how it feels, but I'm wondering if I'll be looking at the diff next. I presume that's the next thing?
Post #761518 2nd Mar 2019 12:54pm
JPE
Took it for a drive & I can't believe what a huge difference changing the half shafts has made. Very Happy
Post #761527 2nd Mar 2019 2:52pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I dont even have to remove the wheels on mine. It literally is a 10 minute job a case of undoing 5 bolts pulling it out and refitting 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #761672 3rd Mar 2019 11:58am
Grenadier
Is it advisable to change half shafts and flanges at the same time? If not, which tend to slacken/fail first? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #761676 3rd Mar 2019 12:10pm
landy andy
In my experience drive flanges fail first due to them being a softer material. They are almost a built in weak link that is easily replaced.
Post #761679 3rd Mar 2019 12:20pm
New parts with new parts is often best yes. Then you know it’s all just right but depends on budget. I doubt I’d go back from the Ashcroft HD type now (Or 1 piece). 2 prince set up is horrendous for ‘fretting’ seeing as the ends of the splines are completely exposed to the elements and can fill with water too. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #761692 3rd Mar 2019 1:50pm
Howard
Ashcroft shafts and end plates
I fitted a set of Ashcroft shafts and hub drive plates a couple of weeks back. Do you assemble the shaft and end plate on dry without greasing the spline as per the original, or apply grease or oil?
Post #761717 3rd Mar 2019 5:38pm
Grease all splines except the spines to diff, if I remember rightly the diff end I just put diff oil over it as a bit of a pre fit lube.
I piece DM's you donn't need any greasing just oil lube the diff splined end.
Lightly grease both sides of the gaskets too and mating surfaces. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #761735 3rd Mar 2019 7:00pm
Grenadier
Do these look right as the Disco upgrade?
Description: LANDROVER DISCOVERY 300 TDI V8 REAR OFFSIDE 24 SPLINE HALF SHAFT THIN FLANGE
Post #761761 3rd Mar 2019 8:34pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I hope so, because I bought them earlier this evening!
He does have more I believe though....
Post #761770 3rd Mar 2019 9:04pm
jst
Re: Ashcroft shafts and end plates
Grease or lubricate or copper slip the out ends where they go into dm.
Interesting why is the dm bolt snapping a greater issue with pumas over earlier lr? Certainly my experience. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #761772 3rd Mar 2019 9:25pm
I'm not sure that ex-Disco ones are right for a 110. It's only in more recent years that the part numbers for both 90 and 110 have been the same. In the 1990's, they were different and the Disco half shafts were shared with the 90 of that era. Darren
Post #761777 3rd Mar 2019 10:29pm
Grenadier
Censored Censored Censored Rolling with laughter
Did you ask if they fit a Puma 110 or are you taking a punt? Monsieur Le Grenadier
Post #761800 4th Mar 2019 7:45am
Joe the Plumber
A punt, but from all the posts on here (in lots of different topics) it looks like they're the right ones.
If not, they'll be for sale again shortly!
Post #761802 4th Mar 2019 8:09am
