|  | Home > Technical > Handbrake Electrical Short |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  | earthing | ||
|  8th Nov 2018 7:16pm |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059    | Check vehicle earths.
 Often the earth to transfer box. The vehicle is using handbrake cable as the earth cable  | ||
|  8th Nov 2018 8:58pm |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21042    | As others have said, but also check brake fluid is nearest the upper max mark too.    ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ | ||
|  8th Nov 2018 11:43pm |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  | handbrake wiring also go up to the  brake fluid level switch | ||
|  9th Nov 2018 7:46am |
| Nuge Member Since: 04 Sep 2017 Location: Den Haag Posts: 2      | Thanks everyone.  It's definitely the chassis ground.  I put a jumper from the battery negative post to the chassis and the issue is gone.  I will install a new chassis strap. | ||
|  10th Nov 2018 5:18pm |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059    |  | ||
|  10th Nov 2018 5:45pm |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  | good    | ||
|  10th Nov 2018 5:46pm |
| Posting Rules
