![]() | Home > Technical > Handbrake Electrical Short |
earthing
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5892 ![]() ![]() |
Check vehicle earths.
Often the earth to transfer box. The vehicle is using handbrake cable as the earth cable ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20775 ![]() ![]() |
As others have said, but also check brake fluid is nearest the upper max mark too.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
handbrake wiring also go up to the brake fluid level switch
Nuge Member Since: 04 Sep 2017 Location: Den Haag Posts: 2 ![]() ![]() ![]() |
Thanks everyone. It's definitely the chassis ground. I put a jumper from the battery negative post to the chassis and the issue is gone. I will install a new chassis strap.
good
