Home > Technical > Handbrake Electrical Short
Nuge
Netherlands 1991 Defender 90 200 Tdi SW Bonatti Grey
I'm having erratic indicator flashing and headlamp dimming when disengaging my handbrake on my 96' 110 300tdi. Everything returns to normal if I pull up slightly on the handbrake handle. I have even disconnected the handbrake switch and the issue remains. I have no clue how the handbrake switch can affect the headlamps and indicators even when disconnected. Any suggestions?
Post #739382 8th Nov 2018 6:59pm
dorsetsmith
earthing
Post #739388 8th Nov 2018 7:16pm
landy andy
Check vehicle earths.
Often the earth to transfer box. The vehicle is using handbrake cable as the earth cable Thumbs Up
Post #739420 8th Nov 2018 8:58pm
custom90steve
United Kingdom 2007 Defender 90 Puma 2.4 SW Stornoway Grey
As others have said, but also check brake fluid is nearest the upper max mark too. Thumbs Up Watts รท Volts = Amps.
Amps X Volts = Watts
Post #739440 8th Nov 2018 11:43pm
dorsetsmith
handbrake wiring also go up to the brake fluid level switch
Post #739456 9th Nov 2018 7:46am
Nuge
Thanks everyone. It's definitely the chassis ground. I put a jumper from the battery negative post to the chassis and the issue is gone. I will install a new chassis strap.
Post #739695 10th Nov 2018 5:18pm
landy andy
Thumbs Up
Post #739698 10th Nov 2018 5:45pm
dorsetsmith
good Thumbs Up
Post #739699 10th Nov 2018 5:46pm
Site Copyright © 2006-2019 Futuranet Ltd & Martin Lewis
