Home > Technical > Puma Central Locking not operating rear doors |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
Hi all,
Just picked up my 2007 110 Puma and have noticed that the Central locking locks both front doors and the back door, but not the rear doors? It's a bit weird why both doors are not working, has anyone got any pointers? Many thanks in advance! Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
30th May 2011 4:32pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4510 |
one of my rear doors would not lock-it turned out to be a broken wire in the rubber sleeve where it bends between the door and the door pillar.Seems like yours are not connected up to the system. 1982 88" 2.25 diesel
30th May 2011 6:46pm |
Thanks Spudfan,
I'll get a multimeter to the wires and check for voltage. Does anyone know where the control unit for the central locking is? Under driver's seat? Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
31st May 2011 7:31am |
Huge thanks, saves a lot of time tracing cables back!!!!! Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
31st May 2011 3:47pm |
Well after some multimeter action, the connector under the driver's seat had power, but both rear doors didn't.
It ended up being exactly as mentioned (and a common problem it seems). Both doors had broken cables within rubber flexi-pipes. Bit of solder later and all doors are now locking. Once again, thanks for all your help!!!! Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
31st May 2011 8:57pm |
