![]() | Home > Technical > ATB (torsen) front and rear install |
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
yep, just the rear --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Weird, as in 8 years there have never been any vibrations, which is why I am so sensitive in detecting them.
Would putting a double-cardan propshaft in the rear solve this? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
If you get the Defender in the air i.e wheels off the ground can you recreate the issue? - maybe you might hear some odd noises?
Could it be tyres off balance or slightly damaged? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
^ I'm thinking of going to spend some time at my indie's workshop to do this.
I just replaced the tyres, brand new Goodyear Wrangler Adventures -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
and the vibrations still present with new tyres. Maybe move the wheels front/rear? 1999 Defender TD5 110
| redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221
As the wear increases, so too will the effect of the vibration, although the source remains the same.
The best way to establish this (without actually trying it) is to check the geometry of the flanges and shaft with the vehicle at normal operating weight. Its the front that is the bigger problem, because its much shorter (so angles are greater) and the flanges are not parallel to begin with. I replaced my front with a DC propshaft, and my problems all but disappeared. I still have a slight vibration (the vehicle has a +40mm lift so rear flanges are not parallel) but I can live with it.
You mean running through the gears with the vehicle off the ground? Bear in mind that with the suspension at full extension the driveshaft will probably be beyond the normal operating rage of the UJ's, so you will definitely experience vibration! Assuming you don't bind the joints...
Anything that rotates could be the cause. The faster the rotation and the heavier the object, the more noticeable the vibration. That said a wheel out of balance should be quite easy to identify at the local tyre shop, and hopefully the first thing that was checked??!! |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2511
Worth to consider
Click image to enlarge Click image to enlarge Maybe post a video to have a feel what you are experiencing Puma 110" SW ............................................................. Earth first. Other planets later |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8481
t box mounts? Cheers
| HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 824
But isn't the engine and gearbox at an angle with the Pumas? If not the engine and the gearbox, at the very least the gearbox rearwards are at an angle. The diagrams presume that the gearbox and engine are parallel to the deck. Maybe a factor to consider as well? |
Just an update on this: fitted a double-cardan prop to the front, and this has alleviated the vibrations at high speeds.
The vibrations at low speeds (50-70) are still present. The car was in the workshop this past week where the entire drivetrain was inspected: wheel bearings checked, props, UJs, driveshafts, etc. We are now going to fit caster-correcting bushes on the radius arms due to a pull to the left, and we will see if that will also help with the vibrations. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
if your going caster corrected you would be better off clocking the swivels and retaining the strong std arms. caster correction with improve return to centre not sure it will make any odds to the vibrations though. Cheers
So the Ironman bushes are in, and the cross caster has gone from -0.53 to -0.32 desgress.
Massive difference in the left pull, and a slight improvement in the vibrations. Taking the landy to a different mechanic next week -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Are both propshafts balanced? Puma 110" SW
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
Is the pinion bolt correctly torqued correctly and not loose?
This is an area I'd be looking, I had a vibration thing around the rear diff in the past and it didn't sound good but would come and go. It then marginally disappeared and was not, propshaft related, diff or DM's. I did however have a leaking pinion oil seal many times, many times there has been no reason for this either.. Once this was sorted out, which also included replacing the pinion flange, fixings and seals the issues were gone. I have not had it since either, even despite another leak last year that was fixed this year. The pinion flange is a Genuine one as is the seal, the original I think was factory too as far as I am aware. In between fixes and garages I went when the vibration was present I am not sure. (There is a possibility in between a non genuine flange was fitted. ) However, it maybe that the pinion was worn and not 'true' and also many aftermarket pinion flanges are of very poor manufacturing tolerance levels. This affects balance in a similar way as the prop shafts do, the pinion bolts can also work loose as well. Sometimes both are combined but wear is more common than the pinion bolt becoming loose. This can cause vibration. The only way to identify it would be to remove the rear prop shaft completely, then the rear halfshafts. (Or 1 piece DM's) This would allow the flange to remain static with no drive through it, if the vibration is gone you've found the culprit. Or at least the pinion or diff. I found removing a prop shaft to determine the axle with the issue was very helpful and you can use this as a method of elimination. Just bear in mind different handling characteristics, go easy and the diff must be locked. The handbrake will work regardless of which prop is removed front OR rear, don't remove the handbrake drum. You may also need a few washers to pack behind the nuts on the transfer box side as the bolts are not fully threaded. Off the top of my head IIRC they were 5/16" washers, you only need around 4x washers on each bolt. If anyone wants to correct me on any of my points please feel free, I did find these methods useful myself though to identify issues. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
