Home > Technical > ATB (torsen) front and rear install
Page 16 of 24 <123 ... 151617 ... 222324>
Naks
Yes, both props were balanced to eliminate them as the source.
Thanks Steve, all that you mention was also done. --
Post #738137 2nd Nov 2018 7:36am
MK
The old short wheelbase Land Cruiser fj40 had as standard a double cardon rear propshaft. Puma 110" SW
Post #738155 2nd Nov 2018 9:35am
Naks
After 3 months of systematic investigation by Elrico (one of the best indies in Cape Town), a new rear propshaft + new flanges has solved about 90% of the issue.
During this time, all the major drivetrain components have been swapped out and/or replaced with no difference: front diff, front propshaft, engine mountings, transfer box, rear propshaft, rear diff, A-frame ball joint, etc.
Even though the original rear prop was showing true on the balancing machine (two separate ones showed it to be perfect), replacing it cured the vibration.
The Puma now drives without any vibration, but there is a loud/low-frequency droning noise from about 40kmh up to around 110kmh, especially when you come off the accelerator. However, unlike the original vibration, it doesn't feel as if something is going to break while driving, so that's a definite improvement.
What is still baffling to anyone who has worked on my Puma is that as soon as the rear propshaft is removed, the vehicle runs beautifully - no noise or vibration whatsoever. Yet, replacing the rear diff, halfshafts, etc., has no effect on the noise/vibration.
Any further suggestions on how to resolve this droning noise would be much appreciated Neutral --
Post #765757 28th Mar 2019 9:34am
MadTom
I had similar problem after change of both diffs to Ashcroft lockers and used KAM 1:3,8 gears on Discovery 2. I was not able to set the right contact pattern on rear diff, I spent quite a long time testing different sets of spacers. Result was howling rear gears. When driving without rear prop shaft, it was quiet. I had to buy new rear gears, setup was just few minutes and result is perfect - no more howling. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #765762 28th Mar 2019 10:40am
Naks
Thanks MadTom
I'm not sure I understand what you mean by new rear gears - do you mean the gears inside the rear diff?
But aren't those the Ashcroft ATB ones? Question --
Post #765764 28th Mar 2019 10:44am
MadTom
No, no connection to Ashcroft ATB, but to the diff and howling. I was installing full lockers from Ashcroft together with slower diff gearing - those 2 big toothed gears. And the howling was problem of these two main gears (ring gear and pinion gear), no inside the locker (or ATB or any other diff centre).
The problem was, that with used gear set, I was not able to set their correct position - they were worn bad, and result was howling. With new gear set, setting the correct position was a piece of cake and result was no noise. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #765767 28th Mar 2019 11:04am
Naks
Ah, I understand.
But in my case, we replaced the rear diff twice, with two different ones from vehicles running smoothly, and still the noise persists.
When we put my diff in another vehicle, there is no noise Shocked --
Post #765768 28th Mar 2019 11:10am
Naks
Defendermatt wrote:
Standard 80/90 gear oil
thanks, is this oil fine then?
SPIRO GEAR 85W140/500ML Question
Quote:
INDY Spiro Gear GL-5 is a range of multipurpose automotive gear oils blended from virgin base mineral oils, which have been fortified with anti-wear, anti-oxidant, anti-foam, anti-corrosion and extreme pressure additives.
INDY Spiro Gear GL-5 Oils are suitable for use in manual gearboxes which call for API GL-5 gear oils. They resist scuffing, abrasive wear, foaming and oxidation even under extreme conditions.
Post #780105 4th Jul 2019 9:17am
Naks
Finally got the landy back after it spent 7 months in the shop.
Besides a thorough investigation into the root cause of the vibrations, the following were replaced:
- rear propshaft
- A-frame ball joint
- rear springs (Terrafirma Heavy)
- all bushes
The landy now drives much better, although there's still a vibration at low speeds coming from the gearbox/transfer case area (bum area) and the rear diff howls at around 80kmh.
Having been without an off-roadworthy landy since Feb 2018, I'm done trying to sort this out any further.
I guess this is a Defender after all, so I shouldn't complain that it isn't safe, comfortable, etc., and just live with the issues. Whistle --
Post #780147 4th Jul 2019 2:13pm
Naks
Happy to report that after 3 weeks of much-needed TLC at a new indie workshop, the vibration is now almost gone and the truck now drives lekker!
they did a complete respray of the chassis, fixed the rear diff vibration, new UJs on both props, new output shaft seal, tightened front left bearing, new rear side shafts & drive members, etc. --
Post #797110 7th Oct 2019 2:54pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Glad you got it all sorted , I’ve had similar problems and also replaced just about everything.
It turns out my front was bent !
Well done for persevering https://www.instagram.com/hustynminepark/
Post #797155 7th Oct 2019 6:56pm
CharlieDonuts
France 2008 Defender 90 Puma 2.4 SW Galway Green
I was planning to drive to ASHCROFT from where I live in France to have ATB differentials fitted front and rear.
With the quarantine on both sides of the channel thats impossible for me to do now.
If I were to mail order the ATB differentials
What level of competence is needed to fit them
Can I do it myself ? do I need to find a mechanic ? does the mechanic have to be expert in differentials ?
Post #832880 23rd May 2020 2:28pm
Naks
You could DIY if you were a diff expert, so best to take it to a very experienced landy rover mechanic Thumbs Up --
Post #832885 23rd May 2020 2:49pm
Were you planning on buying just the diffs and building them into your existing pinion housings, or buying built up units and just swapping the assemblies?
Either is fairly straightforward but the former is not for the faint-hearted and requires some special tools, the latter is an easy DIY job.
Post #832886 23rd May 2020 3:01pm
CharlieDonuts
Easy DIY job meaning me and my mate and the workshop manual ?
How many people does it take to lift a differential. I was thinking about the delivery.
Post #832893 23rd May 2020 3:31pm
