![]() | Home > Puma (Tdci) > 'ardcase arrived |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated
IID Pro MV License |
| Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 245
Out of interest, what made you choose the 'ardcase over the Adrenaline pedal lock boxes than cover the entire pedal area?
Harry 1990 Defender 110 200TDI Camper - now converted to Td5 power |
Key ring and LR logo are my options.....
The systems that block the pedals are rated like the best anti theft from independent italian car theft observatory.... And Adrenaline one is too "BIG"..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
It is big, but i think you'd struggle to remove it! I've never found it annoying (unless it breaks free from its storage space and starts sliding around the back if the 90!) i've heard stories of pedal locks like the 'ardcase and clutch claw (centinel) having the pedals cut using bolt cutters and then the landy being driven using the 'stumps'. Just my 2pence worth! Harry 1990 Defender 110 200TDI Camper - now converted to Td5 power |
I have another problem......
'Ardcase does not fit the LHD pedals!!!! Throttle and clutch are fine but the brake one not!!! Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated
IID Pro MV License Last edited by dgardel on 16th May 2011 4:59pm. Edited 1 time in total |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
Two minutes with an angle grinder on the box should put that right - might spoil the paint finish though. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505
If they want it they will still take it pedals or no pedals
Yes sure
but more than 2 min, because the pedal have interference with the piece of metal where the latch go inside and with the lock mechanism..... Need to shift to right up the throttle pedal permitted (all the holes must be "grindered")... just advised MUD STUFF so I'm waiting the reply before go to my garage ad start to modify..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
| Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384
Looks like the pedal will be in the way of the lock then!
My adrenaline lock is excellent, plus i know the lad who makes them. |
| Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306
Why not fix qn alarm gun on the drivers door connected to the pilar?!! If nothin else the
| Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026
Can you have a word with him and ask him to hurry up and make one that is XS & Air con compatible. I am waiting for them to make one - anything to make the scroats think twice or slow them down. |
Will ask.
He probabally needs a puma defender to model it on. |
| All times are GMT |
