Home > Maintenance & Modifications > Installing a aux power socket in the rear
Page 9 of 11 <123 ... 8 91011>
qwert
2015 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
LoveTheMud wrote:
So as a few have said, the later models don't have it, I have 13 pin electrics that I wired up but don't remember seeing a spare wire, I've removed and broken a few plastic screw things but I can get those from halfords. My question is this, are there any other points in the rear where it's just a plug and play piece for aux? I bought a ford aux socket as it matches up perfectly but I now don't have the wire...
I can see a purple under the wheel arch from my 13pin electrics (photo) being utilised... So I'm stuck
Hi all.
I have 2015 110 Heritage and after reading whole thread could not figure how to bring purple and ground wire from the place in the picture ( from behind rear right wheel ) to the space behind speakers. Could someone explain please?
Thank you, qwert.
Post #569850 10th Oct 2016 12:16pm
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
This is an awesome thread. But I'm still confused on where to find the mystery wire on my 2013sw. Can anyone who did it let me know. I got more confused reading the 9 pages on info. Thx!
Post #576041 7th Nov 2016 2:51pm
sjwdrew
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
My first bit of modification complete! Kinda fun!!
Post #585555 16th Dec 2016 12:47pm
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Thank you! Nice modification which I've now added to mine Smile My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #605804 1st Mar 2017 7:14pm
Lancerdoc999
any reason why I couldn't use this for dual functionality? Is from flatdog and would also provide usb charging at the rear.
Post #607710 7th Mar 2017 11:26pm
meeerrrk
Power wise there is no reason, just piggy back it off the one feed. You'll just need to find somewhere to physically mount it Thumbs Up My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #607741 8th Mar 2017 6:19am
X4SKP
There is room indeed...I see your 2 and raise you 3... Shocked
Finally got around to implementing this mod'...
X2 12V Power Output Points + X2 USB 5V / 2.1A Outputs
All Supplied from MUD UK (Exc' X3 Mounting Plate)
http://www.mudstuff.co.uk/products/electri...plugs.html
Perfect location for rear work power needs / charging...(Thanks) Thumbs Up SKIP
Post #645452 21st Aug 2017 5:07pm
Coatesyyy
Great mod! On my to do list this weekend now! Thank you Thumbs Up
Post #652093 22nd Sep 2017 4:09pm
m3vert
Scotland 2011 Defender 110 2.5 TD PU Stornoway Grey
Sorry to pull up an old thread! I am looking to do this in my 2011 110 double cab pick up. Will this purple wire be there in mine? If so where??
I am looking to be able to power a small fridge and I also need somewhere to plug in a trickle charge solar panel, needs to be in a permanent live.
Thanks in advance for any help Cool
Post #702329 22nd Apr 2018 12:38pm
LR90XS2011
should be rear drivers side corner or in that vicinity, some have found them underneath the body taped to the loom in the same general area DEFENDER 90 TDCI XS,
Post #702361 22nd Apr 2018 3:11pm
m3vert
Many thanks Smile When I get home from this work trip I will have a look for it, cheers
Post #702443 22nd Apr 2018 8:02pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Here’s mine. Twin 12v accessory sockets. Both running off the auxiliary battery. One is permanent live and the other ignition live.
Also completed today, ply lining panels wrapped with black trim velour.
Post #707988 18th May 2018 10:47pm
m3vert
Well I had a look for this elusive purple wire and cannot find it on my 2011 110 double cab pick up Sad
Post #708732 23rd May 2018 10:13am
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Installed a rear power point in my 2011MY USW XS today but added a relay to ensure that power is turned off with the ignition.
A cool box left running overnight would leave me stranded with a flat battery, and I know that it probably would happen Whistle
There are lots of pics above of the power point.
This is what I found behind the speaker
Purple wire runs to the power in relay terminal, + terminal of power point is fed from the power out relay terminal.
Earth for both the relay and power point taken from black wire attached to L shaped connector with the purple wire.
The ignition live feed to trigger the relay was picked up from this connector for the rear wash wipe.
Post #710495 2nd Jun 2018 8:42pm
big110
still unclear
read all 9 pages....whats the story with a 2014 110?
Post #719962 27th Jul 2018 2:01pm
