Home > Maintenance & Modifications > Installing a aux power socket in the rear |
big110 Member Since: 02 Nov 2016 Location: Sweeden Posts: 342 |
This is an awesome thread. But I'm still confused on where to find the mystery wire on my 2013sw. Can anyone who did it let me know. I got more confused reading the 9 pages on info. Thx!
7th Nov 2016 2:51pm |
sjwdrew Member Since: 31 Aug 2016 Location: London Posts: 18 |
My first bit of modification complete! Kinda fun!!
Click image to enlarge |
16th Dec 2016 12:47pm |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 |
Thank you! Nice modification which I've now added to mine My 90 Project : http://www.defender2.net/forum/topic52774.html
1st Mar 2017 7:14pm |
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 |
Click image to enlarge Click image to enlarge any reason why I couldn't use this for dual functionality? Is from flatdog and would also provide usb charging at the rear. |
7th Mar 2017 11:26pm |
Power wise there is no reason, just piggy back it off the one feed. You'll just need to find somewhere to physically mount it My 90 Project : http://www.defender2.net/forum/topic52774.html
8th Mar 2017 6:19am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2288 |
There is room indeed...I see your 2 and raise you 3...
Finally got around to implementing this mod'... X2 12V Power Output Points + X2 USB 5V / 2.1A Outputs All Supplied from MUD UK (Exc' X3 Mounting Plate) http://www.mudstuff.co.uk/products/electri...plugs.html Click image to enlarge Perfect location for rear work power needs / charging...(Thanks) SKIP https://www.defender2.net/forum/topic83242.html |
21st Aug 2017 5:07pm |
Coatesyyy Member Since: 07 Sep 2017 Location: Knutsford Posts: 423 |
Great mod! On my to do list this weekend now! Thank you
22nd Sep 2017 4:09pm |
m3vert Member Since: 15 Mar 2018 Location: Central Scotland Posts: 162 |
Sorry to pull up an old thread! I am looking to do this in my 2011 110 double cab pick up. Will this purple wire be there in mine? If so where??
I am looking to be able to power a small fridge and I also need somewhere to plug in a trickle charge solar panel, needs to be in a permanent live. Thanks in advance for any help |
22nd Apr 2018 12:38pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3615 |
should be rear drivers side corner or in that vicinity, some have found them underneath the body taped to the loom in the same general area DEFENDER 90 TDCI XS,
22nd Apr 2018 3:11pm |
Many thanks When I get home from this work trip I will have a look for it, cheers
22nd Apr 2018 8:02pm |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
Here’s mine. Twin 12v accessory sockets. Both running off the auxiliary battery. One is permanent live and the other ignition live.
Also completed today, ply lining panels wrapped with black trim velour. Click image to enlarge Click image to enlarge |
18th May 2018 10:47pm |
Well I had a look for this elusive purple wire and cannot find it on my 2011 110 double cab pick up
23rd May 2018 10:13am |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 832 |
Installed a rear power point in my 2011MY USW XS today but added a relay to ensure that power is turned off with the ignition.
A cool box left running overnight would leave me stranded with a flat battery, and I know that it probably would happen There are lots of pics above of the power point. This is what I found behind the speaker Click image to enlarge Purple wire runs to the power in relay terminal, + terminal of power point is fed from the power out relay terminal. Click image to enlarge Earth for both the relay and power point taken from black wire attached to L shaped connector with the purple wire. The ignition live feed to trigger the relay was picked up from this connector for the rear wash wipe. Click image to enlarge |
2nd Jun 2018 8:42pm |
read all 9 pages....whats the story with a 2014 110?
27th Jul 2018 2:01pm |
