Home > Off Topic > My RRC project
Page 16 of 53 <123 ... 151617 ... 515253>
Procta
grafty99 wrote:
Body's are completely different to defenders. The roof, wings and doors are the only bolt on panels - the rest is spot welded. As I replace panels I am seam welding them in to prevent moisture getting between the panels and in the box sections Thumbs Up
I will see if I can find the link to the sealant I used for patch my dads seatbox up, It will help bond the panels together in areas you cannot weld. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #682816 30th Jan 2018 7:03am
grafty99
Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #682828 30th Jan 2018 9:22am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Good to see it taking shape, Thumbs Up
What is the shell like, has it still got all it’s door pillars and sills? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #682837 30th Jan 2018 10:25am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Been a while since I checked in on this, wow Grafty it’s really taking shape Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #682838 30th Jan 2018 10:30am
grafty99
Thanks chaps. The shell is all original inc boot floor. Inner sills are good, outer sills will be replaced.
The main work will be the front end as the inner wings are shot to pieces. Once the sills are sorted the plan is to cut off the front end and get the body on the chassis. That will then allow me to line up the new front end with the chassis and get it all welded on. Then it's just a case of sorting th body panels which are pretty good Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #682884 30th Jan 2018 1:19pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
Just read all 16 pages keep up the excellent work .Back in the day I had a couple of classic Range Rovers first one was a Turbo D and next one had the Mazda 3 litre diesel fitted,I only had one petrol a 3.5 on carbs could not keep up with it's drinking habit.
My Mazda 3 litre Range Rover towing a Jaguar that needed well lots of work.
Post #683023 30th Jan 2018 10:52pm
grafty99
LOOOONNNGGG overdue update on the range rover.
The underside has been primed and undersealed ready for the body to be mounted back onto the chassis. Will be rolling again soon Mr. Green
1990 Vogue SE
Post #692272 9th Mar 2018 8:54pm
L110CDL
Much better Thumbs Up i think the late update is due to the Tea and biscuits consumed Laughing Clayton.
Keeper.
Post #692278 9th Mar 2018 9:11pm
grafty99
Whistle 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #692286 9th Mar 2018 9:25pm
mk1collector
Never mind tea and biscuits you haven't time for those, I've been having withdrawal symptoms with no updates Rolling with laughter Ray
My build thread
Post #692302 9th Mar 2018 9:48pm
grafty99
Not to worry Ray, things should be moving on slightly quicker now Very Happy 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #692305 9th Mar 2018 9:54pm
Procta
yeah not to mention the dodgy dealings too Whistle Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #692684 11th Mar 2018 10:05pm
Procta
was there much to repair underneath? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #692686 11th Mar 2018 10:06pm
grafty99
Not really no. I replaced the bottom 25mm or so of inner sill, mostly as a prevention as it would probably have needed doing in the next couple of years or so. The rest is solid. Inner wings, outer sills and then it just cosmetic bits really Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #692689 11th Mar 2018 10:16pm
Procta
good stuff there grafty! Are you going to seam seal under too? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #692700 11th Mar 2018 10:33pm
