![]() | Home > Off Topic > My RRC project |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Good to see it taking shape,
![]() What is the shell like, has it still got all it’s door pillars and sills? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Been a while since I checked in on this, wow Grafty it’s really taking shape
![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Thanks chaps. The shell is all original inc boot floor. Inner sills are good, outer sills will be replaced.
The main work will be the front end as the inner wings are shot to pieces. Once the sills are sorted the plan is to cut off the front end and get the body on the chassis. That will then allow me to line up the new front end with the chassis and get it all welded on. Then it's just a case of sorting th body panels which are pretty good ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 ![]() ![]() ![]() |
Just read all 16 pages keep up the excellent work .Back in the day I had a couple of classic Range Rovers first one was a Turbo D and next one had the Mazda 3 litre diesel fitted,I only had one petrol a 3.5 on carbs could not keep up with it's drinking habit.
![]() Click image to enlarge My Mazda 3 litre Range Rover towing a Jaguar that needed well lots of work. |
LOOOONNNGGG overdue update on the range rover.
The underside has been primed and undersealed ready for the body to be mounted back onto the chassis. Will be rolling again soon ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11074 ![]() ![]() |
Much better
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Never mind tea and biscuits you haven't time for those, I've been having withdrawal symptoms with no updates
![]() My build thread http://www.defender2.net/forum/topic17615.html |
![]() Not to worry Ray, things should be moving on slightly quicker now ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5369 ![]() ![]() |
yeah not to mention the dodgy dealings too ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
was there much to repair underneath? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Not really no. I replaced the bottom 25mm or so of inner sill, mostly as a prevention as it would probably have needed doing in the next couple of years or so. The rest is solid. Inner wings, outer sills and then it just cosmetic bits really
good stuff there grafty! Are you going to seam seal under too? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
