![]() | Home > Technical > ATB (torsen) front and rear install |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680
yes mine had done 20k as well. It was a fairly quick and easy job as no need to mess with the pinion bearings. I have done 200 miles since I fitted mine and all good so far, got a couple of trips coming up will do the front when I get back. Actual worst bit for me was trying to lift the diff housing back into the axle whilst lying under the vehicle. DEFENDER 90 TDCI XS,
| Arierep Member Since: 13 Apr 2013 Location: Portugal Posts: 258
Hi again,
Does anyone have more info on the relationship between big tyres (35") and ATBs? |
800 miles now and no leaks no funny noised and imperceptible on road, , need to get the spanners back out and do the front now or may pay Ashcroft to do it DEFENDER 90 TDCI XS,
I hope everyone is well and your land rovers make you happy Last edited by LR90XS2011 on 30th Oct 2017 8:20pm. Edited 2 times in total |
Just purchased a couple of ATBs, to go front and rear this week.
For will be on the 255/85R16s |
| wdef34 Member Since: 26 Sep 2017 Location: ....................... Posts: 15
Good for you man,you will love it, you ll see!
Yeah, I hope so. Those things weren't cheap, a single air locker would have been much less, since I already have onboard air installation.
But they were a much easier investment to justify with the wife (it's our money after all). They're always on and contribute to on road safety |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11091
^^^ Following your new mod with interest
Hi all,
Been using the ATBs front and rear since last friday. Very pleased with them on the road, car feels much more stable and the return to center feel is very nice. My steering wasn't awful, but the taller suspension and -25mm offset rims weren't helping. It now feels fantastic. Very little offroad for now. The track I was using for testing was closed this weekend, so had to resort to some easy trails close to home. A sand pit which used to cause me some trouble is now doable like it's solid ground, to the point of being boring. I can now drive diagonally against a nearly vertical hill and keep going to the point of lifting a wheel and nearly tipping over. Wheels used to start spining as soon as I was approaching the limit of suspension travel. I managed, however, to get stuck in a severe crossaxle up a small hill... |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946
Thanks for the update Jose, good to read
Getting stuck in the cross axle going over the boulder got me a little worried. I tried to apply left foot braking the best I knew with no results.
This is not the kind of obstacle I usually do, but nonetheless was expecting more reaction from left foot braking. Next weekend I'm going to a different obstacle track which has some nice deep axle twisters. That's more in line with the kind of stuff which used to stop me with open diffs. If the ATBs or left foot braking fail to get me through then I might consider something different to the rear axle |
Just came back from the obstacle track. It was partially flooded but fun as well.
I'm amazed by the diffs. They just work, even in severe axle twisters. When a wheel is really leaving the ground (you feel a shutter) simply touch the brake and there you go. Sold, sold, sold |
Great! Best get saving
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
chaps, what oil should be used with the ATBs?
thanks -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
| Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313
Standard 80/90 gear oil
