Home > Technical > ATB (torsen) front and rear install
Page 12 of 24 <123 ... 111213 ... 222324>
LR90XS2011
yes mine had done 20k as well. It was a fairly quick and easy job as no need to mess with the pinion bearings. I have done 200 miles since I fitted mine and all good so far, got a couple of trips coming up will do the front when I get back. Actual worst bit for me was trying to lift the diff housing back into the axle whilst lying under the vehicle. DEFENDER 90 TDCI XS,
Post #646496 26th Aug 2017 10:25pm
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
Hi again,
Does anyone have more info on the relationship between big tyres (35") and ATBs?
Post #649737 12th Sep 2017 7:34am
LR90XS2011
800 miles now and no leaks no funny noised and imperceptible on road, , need to get the spanners back out and do the front now or may pay Ashcroft to do it DEFENDER 90 TDCI XS,
Post #650486 15th Sep 2017 5:50pm
wdef34
Hi, as far as big tyres and ATB, i have 900r16 (34.5inch narrow though) and ATB on the front. No worries at all the diff is far more capable than you think. I also have ARB on the salisbury which i rarely use since the installation of the ATB. But i dont do challenge style off roading. As for tarmac a little return to center tendency which goes away after 1k miles nothing to worry about believe me. Indtallation is straight forward videos and torque settings available from aschroft site.I think you wont be dissapointed.
Post #653812 30th Sep 2017 11:29am
Arierep
Just purchased a couple of ATBs, to go front and rear this week.
For will be on the 255/85R16s
Post #653818 30th Sep 2017 11:59am
wdef34
Good for you man,you will love it, you ll see!
Post #653820 30th Sep 2017 12:20pm
Arierep
Yeah, I hope so. Those things weren't cheap, a single air locker would have been much less, since I already have onboard air installation.
But they were a much easier investment to justify with the wife (it's our money after all). They're always on and contribute to on road safety
Post #653827 30th Sep 2017 1:23pm
L110CDL
^^^ Following your new mod with interest Whistle Clayton.
Keeper.
Post #653975 30th Sep 2017 9:41pm
Arierep
Hi all,
Been using the ATBs front and rear since last friday.
Very pleased with them on the road, car feels much more stable and the return to center feel is very nice. My steering wasn't awful, but the taller suspension and -25mm offset rims weren't helping. It now feels fantastic.
Very little offroad for now. The track I was using for testing was closed this weekend, so had to resort to some easy trails close to home.
A sand pit which used to cause me some trouble is now doable like it's solid ground, to the point of being boring.
I can now drive diagonally against a nearly vertical hill and keep going to the point of lifting a wheel and nearly tipping over. Wheels used to start spining as soon as I was approaching the limit of suspension travel.
I managed, however, to get stuck in a severe crossaxle up a small hill...
Post #657950 17th Oct 2017 8:04pm
JOW240725
Thanks for the update Jose, good to read Thumbs Up James
Instagram @suffolk_rovers
Post #657966 17th Oct 2017 8:43pm
Arierep
Getting stuck in the cross axle going over the boulder got me a little worried. I tried to apply left foot braking the best I knew with no results.
This is not the kind of obstacle I usually do, but nonetheless was expecting more reaction from left foot braking.
Next weekend I'm going to a different obstacle track which has some nice deep axle twisters. That's more in line with the kind of stuff which used to stop me with open diffs.
If the ATBs or left foot braking fail to get me through then I might consider something different to the rear axle
Post #657994 17th Oct 2017 10:14pm
Arierep
Just came back from the obstacle track. It was partially flooded but fun as well.
I'm amazed by the diffs. They just work, even in severe axle twisters. When a wheel is really leaving the ground (you feel a shutter) simply touch the brake and there you go.
Sold, sold, sold
Post #658787 21st Oct 2017 6:52pm
JOW240725
Great! Best get saving Thumbs Up James
Post #658827 21st Oct 2017 8:49pm
Naks
chaps, what oil should be used with the ATBs?
thanks --
Post #662566 8th Nov 2017 8:24am
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
Standard 80/90 gear oil
Post #662596 8th Nov 2017 11:25am
