Home > Maintenance & Modifications > Clear Indicator lenses
Page 3 of 4 <1234>
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
If you mean LED stop/tail bulbs to go inside clear lenses, then yes. Look at my second post on the previous page.
Pete
Post #64793 22nd Mar 2011 11:26pm
Pete
Cheers, Quite expensive were they a straight swap new for old?
Post #64845 23rd Mar 2011 11:55am
XS Pete
Yes, very simple fit. The LED cluster is mounted in a standard bulb base so it's a straight swap, and at £15 for two, I didn't think they were too expensive.
Pete
Post #64852 23rd Mar 2011 3:57pm
Pete
Sorry my mistake I only looked quickly I assumed it was £15 each!
Post #64854 23rd Mar 2011 5:21pm
XS Pete
No problem. I wanted to make sure that you werent looking at the wrong link. The first link I posted on the first page of the thread for the fog lamp LED cluster wes £15 each.
Pete
Post #64862 23rd Mar 2011 7:37pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Thanks XS PETE, I received my stop and tail bulbs today and fitted them they are 100 time better than the painted red ones i had from bolt on bits Thumbs Up
http://cgi.ebay.co.uk/Land-Rover-Land-rove...3727wt_922 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #65094 25th Mar 2011 7:34pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
are the LED's brighter on tail or stop or about the same brightness? BM52
Post #65095 25th Mar 2011 8:08pm
fekete
There brighter but you need clear lenses as they are designed for clear Thumbs Up
A lot of people misunderstand the colour choice for an LED bulb. A red LED will work better behind a red lens than a white LED! An amber LED will work better behind an amber lens than a white led! Both colours will work equally well through a clear lens. NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #65102 25th Mar 2011 9:06pm
bm52
you convinced me. just ordered some - cheers Thumbs Up BM52
Post #65107 25th Mar 2011 9:23pm
fekete
bm there good worth the 15 quid Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #65121 25th Mar 2011 11:31pm
I take it there isn't any problem using them with clear or red lenses? As clearly seeing as the LED's are a better red than the painted filament then they are much more suitable for clear lenses. If however i wasnted to buy the LED's for now and the lenses at a later date surely the standard red lenses would be okay for the time being along with the red lenses? Or would it be better to stick to standard unless both bulbs and lenses are changed.
Post #65286 27th Mar 2011 8:28pm
fekete
I would just get them and try them as its only 2 screws and a few minutes to try them Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #65289 27th Mar 2011 8:33pm
bm52
.....that's exactly what I plan to do when they arrive. if i can i will take a piccy of one standard bulb and one LED under a red lense on both tail and brake lights to see the difference.
the only reason i am bothering changing to LED is to get a bit more light at the rear, so many new cars are plastered with rear lights and brake lights the puney Defender lights don't seem that bright to me Confused BM52
Post #65292 27th Mar 2011 8:44pm
Agree with both of you above. Easy to fit and only £15 for a pair will buy soon. Have any of you got any before and after pics at all that would be good to see?
Post #65380 28th Mar 2011 1:01pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
Fitted the lamps off eBay today, looking good.
Anyone replaced the high level break lamp for a LED version?
Post #65973 2nd Apr 2011 10:29am
Page 3 of 4 <1234>
