![]() | Home > Maintenance & Modifications > Clear Indicator lenses |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
Cheers, Quite expensive were they a straight swap new for old? |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
Yes, very simple fit. The LED cluster is mounted in a standard bulb base so it's a straight swap, and at £15 for two, I didn't think they were too expensive.
Pete |
Sorry my mistake I only looked quickly I assumed it was £15 each! |
No problem. I wanted to make sure that you werent looking at the wrong link. The first link I posted on the first page of the thread for the fog lamp LED cluster wes £15 each.
Pete |
Thanks XS PETE, I received my stop and tail bulbs today and fitted them they are 100 time better than the painted red ones i had from bolt on bits
![]() http://cgi.ebay.co.uk/Land-Rover-Land-rove...3727wt_922 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
are the LED's brighter on tail or stop or about the same brightness? BM52
There brighter but you need clear lenses as they are designed for clear
![]() A lot of people misunderstand the colour choice for an LED bulb. A red LED will work better behind a red lens than a white LED! An amber LED will work better behind an amber lens than a white led! Both colours will work equally well through a clear lens. NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
you convinced me. just ordered some - cheers
bm there good worth the 15 quid
I take it there isn't any problem using them with clear or red lenses? As clearly seeing as the LED's are a better red than the painted filament then they are much more suitable for clear lenses. If however i wasnted to buy the LED's for now and the lenses at a later date surely the standard red lenses would be okay for the time being along with the red lenses? Or would it be better to stick to standard unless both bulbs and lenses are changed.
I would just get them and try them as its only 2 screws and a few minutes to try them
.....that's exactly what I plan to do when they arrive. if i can i will take a piccy of one standard bulb and one LED under a red lense on both tail and brake lights to see the difference. the only reason i am bothering changing to LED is to get a bit more light at the rear, so many new cars are plastered with rear lights and brake lights the puney Defender lights don't seem that bright to me ![]() |
Agree with both of you above. Easy to fit and only £15 for a pair will buy soon. Have any of you got any before and after pics at all that would be good to see?
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
Fitted the lamps off eBay today, looking good.
Anyone replaced the high level break lamp for a LED version? |
