Home > Maintenance & Modifications > Roof Spot lights and A bar spots
Page 6 of 7 <1234567>
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
Yes, just wire the high beam wire to a + connection, No 30 on the relay power side.
They will then just switch with the dash switch.
Post #53997 19th Jan 2011 8:21pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Nice one Paul where do's the battery one go to number 86 then ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #53998 19th Jan 2011 8:25pm
Paul_1978
You can run one in from the battery + terminal, or find a spare in the fuse box.
Remember to fuse as close as you can to the + connection.
If you want them controlled off the switch, at the relay, wire connections No 30 & No 86 together, rest as per diagram.
Want me to come and do it for you? Laughing
Post #54000 19th Jan 2011 8:31pm
fekete
Rolling with laughter Rolling with laughter it would save you a lot of time trying to explain it to me .......i think i've got it now thanks ill try it and let you know.....i will be back when i need advice with the roof spots as there is 4 and i need 2 relays wiring together Whistle NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #54002 19th Jan 2011 8:38pm
mse
WHen wiring a relay you have 4 points
a ground for the relay (triggers)
a positive for the relay (triggers)
The excites the circuit and links the +ve in and out of the relay one...just like a big switch
The feed requires very little current around 1amp
You then have:
A feed in (main load)
A feed out (main load)
This is for ease the the power from the battery to the light broken by the relay. Carrying a current up to the relay's max (ignoring wire lengths etc etc)
Whether you switch the ground on and off or the live on and off, makes no difference - as we are switch the low current side of the relay. Nothing is live any more or less of the time!
All you are doing is connecting either side of the trigger - stopping the power at a switch or stopping at a relay doesnt matter - in fact i would suggest stopping at a relay is better than the switch.
As for uses - anything with a +ve feed i fuse - so in all my circuits the 1amp feed will be used at 1 amp and the load will be fused appropriately to the load so say 15amps etc Mike
Post #54047 20th Jan 2011 12:24am
mse
Its dead easy - you will be fine Thumbs Up
4 relays and a switch
Power to the switch - power from the switch to the relay (x2 if only using one switch)
at each relay
Power from battery to relay
Earth to relay
Power from relay to lights
Word of advice...wire you spotlights in equal pairs to the relay eg: external together, central together.
That way they will be legal as spotlights and light equal.
Its also easier to Identify a the failure (especially when you have 6 like i do on the disco) Mike
Post #54048 20th Jan 2011 12:28am
fekete
Cheers Mike i'm full of confidence after all your help and the diagram's of you and Paul Mr. Green Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #54069 20th Jan 2011 10:01am
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Any reason you could not use a larger (amp rating) relay and run 4 spots from one relay? Confused
Post #54112 20th Jan 2011 3:08pm
leeds
Don't see why not as long as everything is suitably rated/fused.
However you would lose 'flexibility' i.e. all 4 on or off
Having them wired in pairs you can try different light combinations and find out what is best for the conditions you are driving in.
Top lights I recommend NOT wiring through the main beam switch. OK that is illegal for UK road use. However if/when the main light switch melts/fails you have an independent set of lights to drive by. It can be rather useful if your main light switch fails as you go around hairpin bends. Whistle A useful back up
Brendan
Post #54120 20th Jan 2011 3:26pm
kingofthesparks
want to fit worklight on rear but want switch in dash, whats best way to route cable, assume that above roof lining is best, has anyone done this if so can it be fished or do i need to remove, also where is best to get a live feed to switch for triggering relay,
Post #55323 27th Jan 2011 4:30pm
leeds
Why a relay for a work light?
Why not use a LED light, much reduced current draw so no relay required. LED lights vary from about 1-10 watts in comparison to standard 55 watt work light. Yes LED lights cost more then cheapest worklight at about £10. LED start around £40+ and can get to extremely silly money
If got roof rack fitted take wiring along roofrack, down snorkel through bulkhead into dash.
HTH
Brendan
Post #55333 27th Jan 2011 4:54pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
@leeds: got any good LED worklights you could recommend? I want to get one but I assume there are good 'uns and bad 'uns One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #55341 27th Jan 2011 5:10pm
PaulMc
mse wrote:
The difference between that diagram and mine is mine switches earth not +ve.
Most land rover stuff swtiches at earth (less cables to run
I drew that that diagram and if you look at it, you'll see that the switch IS switching the earth side of the relay.
If YUG000540LNF is wired in any other way, the illumination and tell-tale LEDs don't work.
Although, with a simple internal modification, YUG000540LNF can be turned into a 'traditional' live-switching switch, details here -
http://www.defender2.net/forum/topic552-15.html
mse wrote:
I actually beg to differ in this application.
Spotlights have their own +ve anyway without any input from the fact the switch is driving the earth circuit - the +ve is a feed from the battery via the relay to the lights all the earth feed is doing is the exact same thing as the +ve swtich feed - which is making the relay able to switch the current - both earth and feed only need an amp at most.
I also wouldnt wire it like that (although i accept its a wiring diagram issue probably) if i was wiring to +ve
Confused How would you wire it then?
. Paul.
Post #55354 27th Jan 2011 6:02pm
JSG
Bear in mind that LED lights give you a much narrower spread of beam than a halogen lamp. John
2011 Tdci 110 CSW XS
Post #55356 27th Jan 2011 6:11pm
kingofthesparks
thats why i want a traditional one, has anyone run cables above headlining and how easy was it
Post #55364 27th Jan 2011 6:47pm
