Home > Maintenance & Modifications > Roof Spot lights and A bar spots
Page 4 of 7 <1234567>
leeds
IF you think that is expensive then try the Ligthforce wiring kit from Devon. Thick end of �52!
30 amp relay is what? �2-3?
Land Rover switch and housing sub �10? The switches in most of the kits are unlikely to be compatible with the blank switch panels in a Puma
A fuse and wire? Say a couple of � if you don't have them already.
HTH
Brendan
Post #53938 19th Jan 2011 6:33pm
mse
I dont always say this so sit down...Leeds is right Milestone Thud
The LR switch might be more like �11/12 now and a few � for the connector - but its so far better than the ring its not worth a debate Mike
Post #53939 19th Jan 2011 6:35pm
Glynparry25
mse wrote:
My word with those kits...its a good kit but its not very flexible and its expensive for what it is.
I would second that.... the kit comprises of all the parts needed.... but, the wires are too high a gauge, the conectors are as good as a chocolate tea-pot and the relay is not weatherproof at all.
The best universal kit I have worked with is the Lightforce one:
http://www.devon4x4.com/index.php?page=sho...;Itemid=14
Yes it is �50+ but the quality shows through. Otherwise... cheaper option would be to just buy all the seperat components and put it all together Thumbs Up
Glyn Sheep
Just as a warning though. Yes by buying a cheap kit you might save �35, but if it melts through, you either have to buy a new better quality kit (Buy cheap, buy twice) or at the other end of the scale, you need to buy a new truck because yours has set alight.
Post #53942 19th Jan 2011 6:38pm
mse
Plus modern thinwall cable is so much easier to route and work with! Mike
Post #53943 19th Jan 2011 6:39pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Thanks Guys....i have the LR switches already.....but i know nothing about wiring could you put me in the right direction what i need i have got 4 roof spots to wire and 2 front spots.....also what rating wire to get and what rating relays i need...also what fuse box ... if any of you have a wiring diagram that would be great or if anybody could tell me where to mount the relays how far should the inline fuse be from the relay what size fuse...i think you get the picture Whistle NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #53945 19th Jan 2011 6:50pm
Glynparry25
So what you are saying is...... 'fit a kit for me'? Razz
Glyn Sheep
Post #53947 19th Jan 2011 6:56pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
The switch is �6, orded it yesterday from Guy Salmon in Sheffield.
Online sellers all wanted �7 plus �6 postage!
Part number - YUG000540LNF
You dont have to have the plug, you can just solder onto the pins at the back of the switch and put a bit of heat shrink over it.
So far the loom has cost me �6, hopefully finish the job over the weekend.
Post #53949 19th Jan 2011 6:57pm
fekete
What a guy...good man Glyn... Thumbs Up
Glyn i reckon i could do this... just need putting in the right direction...i've even looked at the LR switches and thought Censored lol...i'm in no rush so even if it take me a month this would not be a problem NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #53952 19th Jan 2011 7:01pm
mse
Im surprised its now only �6 it was more - although i got it through sources
THe plug is a much better the soldering the pins (which is awquard anyway) for a few pounds! Mike
Post #53953 19th Jan 2011 7:02pm
fekete
Paul i have the LR Switchs and the plug that go's in the back Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #53954 19th Jan 2011 7:02pm
mse
You didnt say search for all the fitting info on here Rolling Eyes (even search for my post about doing it) Mike
Post #53957 19th Jan 2011 7:05pm
fekete
Cheers Mike ill have a look Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #53961 19th Jan 2011 7:09pm
mse
always welcome
http://www.defender2.net/forum/topic795.ht...ght+switch
Here she is Mike
Post #53963 19th Jan 2011 7:10pm
fekete
Nice one mate Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #53964 19th Jan 2011 7:12pm
Paul_1978
Ive orded it now and paid, doh!
Thanks.
Ive been looking for the diagram, i had a print out, but a bit of searching and ive found it..
Post #53968 19th Jan 2011 7:33pm
