![]() | Home > Puma (Tdci) > launch control :) |
TDCi Guy Member Since: 17 Aug 2014 Location: Yorkshire Posts: 286 ![]() ![]() ![]() |
I saw that IRB and Alive both had videos of this on Facebook this week. A nice party trick but you'd have to stockpile half shafts if you were thinking of using it often! Tom
@tditomprice 100” Defender Hybrid 2010 Alaska White 90 HT |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Its not launch control is rpm limitation when clutch is pressed. To use it as launch control even with the rpm limited to 2000rpm is a ridicules idea and will no doubt and it tears when the car does not set off from a broken half shaft as already mentioned.
Real launch control is way way more complex than this when implemented correctly. This so-called launch control some are offering is no more thank a gimik and should be avoided if you have mechanical respect for your car. ![]() Regards Pete. |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
I agree.
And would only consider using it on loose ground - it did go rather well however when I tried it ![]() For me it's rather useful to avoid accidental over revving ![]() But as said I think wasn't intended to be anything more than a gimmick. |
