Home > Puma (Tdci) > launch control :)
Page 2 of 2 <12
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
I saw that IRB and Alive both had videos of this on Facebook this week. A nice party trick but you'd have to stockpile half shafts if you were thinking of using it often! Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #531527 14th May 2016 6:26pm
bell-auto-services
Its not launch control is rpm limitation when clutch is pressed. To use it as launch control even with the rpm limited to 2000rpm is a ridicules idea and will no doubt and it tears when the car does not set off from a broken half shaft as already mentioned.
Real launch control is way way more complex than this when implemented correctly.
This so-called launch control some are offering is no more thank a gimik and should be avoided if you have mechanical respect for your car. Smile
Regards Pete.
Post #531562 14th May 2016 9:55pm
Caterham
I agree.
And would only consider using it on loose ground - it did go rather well however when I tried it Mr. Green
For me it's rather useful to avoid accidental over revving Very Happy
But as said I think wasn't intended to be anything more than a gimmick.
Post #531567 14th May 2016 10:13pm
bell-auto-services
Thumbs Up
Post #531576 14th May 2016 10:35pm
Page 2 of 2 <12
