Home > Maintenance & Modifications > Puma service what oils / specifications.
Stacey007
Hello
Just had a price back for my local garage (who has service my last cars not a specialist) to do a full service on the DEfender changing all oils.
Engine Oil
Gearbox oil
Diff oil
Brake fluid
120 plus vat plus parts, I can provide parts or he can.
If I provide the oils etc what do I need? type / specification. Would you provide the oils or just let them do it?
Anything else to ask them to check / grease etc (swivel arms?) while its on the ramps?
Thanks
Post #530579 11th May 2016 10:26am
MartinK
Which Defender? TD5? TDCI 2.2 or 2.4??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #530582 11th May 2016 10:37am
Stacey007
Sorry good point,
Its a 2.4 Puma.
Is there a complete kit I can buy rather than searching for all the different oils?
Thanks
Post #530583 11th May 2016 10:49am
Stacey007
I've gone on opie oils and chosen this lot.
Which is 98.66 including vat
This should do the diffs, gearbox and engine.
The this kit for the filters
38 ex vat (45.60)
So 98.66 plus 45.60 = 144.26 in parts inc vat (this does not include brake fluid)
120 for the labour part plus Vat. 144
Total 288.26 inc vat for Service, All fluids changed and air / fuel filter. Sounds ok? as this all should not need doing that often?
Post #530588 11th May 2016 11:07am
MartinK
Duckworths do a service kit for the non-oils (if you want "genuine"):
http://www.duckworthparts.co.uk/landrover/..._Kits.html
Usually I buy oils from Opie Oils:
http://www.opieoils.co.uk/c-2354-lookup-re...ilter=2011
Much cheaper than Halfrauds...
Full details of all oils here including the service schedule:
http://www.defender2.net/forum/topic8707.html
WRT to the service schedule...
1. Do engine oil and engine oil filter every 12 months / 12000 miles (Service A)
2. every 2 years or 24000 miles, I do the air filter, fuel filter, diff, transfer and gearbox oils... (Service B)
3. every few years (3 or more) do the brake fluid & coolant
Land Rover recommend only changing diff/gearbox oils very infrequently (80k km or something.. detaioled on the service sheet in the post above)
If you want to be lazy, and but all-in-one, I would phone Dan at Duckworth and see if he can to the full kit... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #530589 11th May 2016 11:10am
MartinK
save you looking for the service schedule:
Post #530591 11th May 2016 11:16am
Stacey007
Hello
My cars on 68K and I think the service actual due 72K although full service history no ticks in the book what was done on the last service just a stamp.
Given this will probably be kept, no harm in changing everything for new? plus in August its off to Europe for a road trip.
I think I've chosen all the correct oils off the thread you mentioned although the service kit is a lot more from Duckworth than the premium version of Landrover specialist site?
Think I've got all covered except the brake fluid. (1L for around 10)
So just shy of 300 inc vat all done?
Oil
Diffs
Brakes
Gearbox
Oil filter
Air Filer
Anything else I've missed
Post #530596 11th May 2016 11:30am
MartinK
Definitely -I would do a full "B" service, all oils, engine oil filter, air filter, fuel filter...
Probably would leave the coolant and brake fluid though... they can test brake fluid (you can buy a brake fluid condition meter for a few ) to see if it is contaminated by water - if not contaminated...no need to change it...
Hard one to argue regards which filters to use. I buy from Duckworths. LR don't make filters I guess, so a good quality brand is probably the same item at less cost.
But as it's only 15/year cost difference, personally I'll stick with genuine filters... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #530597 11th May 2016 11:32am
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
I get my service items from Advanced factors. LINK
They do full OEM (Mahle) service kits with or without oil. (I get my oil from Halfords - the Mobil with a trade card is the cheapest I can find.)
They also list gearbox, diff oils and antifreeze etc.
Remember that you don't need all the oils changing on every service.
- Engine oil/filter every 12k miles/1 year
- Fuel/air filter/brake fluid every 24k miles/2 years
- Axle/transfer oils every 36k miles/3 years
- Gearbox oil/coolant every 120k miles/10 years
Theres a service checklist on the forum somewhere with other checks which the garage should carry out on each service as well. Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #530599 11th May 2016 11:37am
Stacey007
Is the 'B' for Big Service.
Think I would be happier, don't know if its be but its sounds a little nosier / dryer from the back so would like it looking at.
Do the oils I have chosen for opie oils sound correct and quantities.?
Many thanks
Post #530600 11th May 2016 11:38am
MartinK
Stacey - they all look like Engine Oil to me...
Engine: You need 7 litres of Engine Oil (with a filter mine goes over 6 litres)
Gearbox: Uses 2.2 litres GL4. I used Castrol Syntrans Multivehicle 75W-90 Fully Synthetic MTF (so you need 3 litres GL4 75w90)
Transfer Box: (2.4 litres). I used Fuchs Titan Race SYN 5 75W-90 Fully Synthetic Gear Oil (was Silkolene SYN 5 75w-90) - this one's GL5 (so you need 3 litres GL5 75w90)
Front & Rear Diffs: Castrol Axle 'EPX' for the Diffs (1.6Litres per Diff) so 4 litres total.
Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #530636 11th May 2016 12:51pm
MartinK
from your manual:
Post #530641 11th May 2016 12:56pm
Stacey007
^ Thanks
I've put all that in the basket on Opie Oil and its comes to 141.94
Will see what the garage come back and say they will charge to supply it.
Thanks
Post #530652 11th May 2016 1:48pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Why not use genuine filters?
Post #530682 11th May 2016 4:29pm
Stacey007
^ No reason I found these that said premium all in a bundle and seemed easy?
If you have a link to the genuine filers and sump plug etc that's great
Thanks,
This is what the Website said for John Craddock spares
Post #530687 11th May 2016 4:45pm
