Home > Maintenance & Modifications > Roof Spot lights and A bar spots
Page 3 of 7 <1234567>
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Anyone know the amp rating of this kit, needed to do 4 spots on roof, 4 x 55 approx 18 amps
Post #52322 11th Jan 2011 8:16am
Glynparry25
The kit comes with 18 Gauge wire so depending on your spots you could wire two into each branch.
Things to think about:
Spot light current
Length of the wire from relay to spots
Relay rating
If you have worked out 18A for all 4 yours, go 20 to be safe, so each wire needs to be minamum of 10, which means a max length 10' before you are getting into trouble.
Hoope this makes sense?
Glyn Sheep
Post #52326 11th Jan 2011 10:04am
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
Thanks for the Info Glyn !! could you email me the instructions please. - nick@seabridge-marine.com
Post #52403 11th Jan 2011 4:45pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
Glyn, where did you get the switch from? Thats exactly what I'm looking for for my rear aux light
cheers dan Thumbs Up
Post #52415 11th Jan 2011 7:40pm
mse
If you do a search on here you will find a few of us with it Whistle Thumbs Up
Its a genuine LR aux light switch - from Land Rover!! Mike
Post #52425 11th Jan 2011 8:42pm
110SEB
Spot light current
Relay rating
Glyn Sheep
Ah Whistle Glyn, this is where i bow to your knowledge. They always say that lawyers would be first out of the nuclear bunker if there wasn't enough food!
If you say the kit could take 4 spots up top then i'll take your word for it. What do i need to make sure the spots are in terms of wattage for when i buy them? Max 55? I'm half tempted to try to get some LR ones, then at least i know they will work (since they supply 4 up top as an extra). Please feel free to highlight any stupid assumptions i may have made.
Post #52437 11th Jan 2011 9:41pm
mse
Im going to sound like a broken record...just make them
Anyway the Genuine wiring is for the front 2 spot lights...its not for four on the top...where they do that and its a LR job the dealer makes them or SV do...ive never seen a kit for that.
Im not so sure i would trust the std wiring kit to run 4 anyway - use the switch as its only a trigger. Mike
Post #52471 11th Jan 2011 11:16pm
Glynparry25
Seb,
I have never heard of Land Rovwer doing a spot kit for the roof rack so wouldn't really just go off that, otherwise I would have thought they would do a full wiring kit for it too...Maybe the Tomb raider had something?.
Anyhoo, for a rough reference (qualiuty of wire can make a difference):
45W at 12v is 3.75A (x2= 7.5A ), max length 20'
55W at 12v is 4.58A (x2= 9.2A ), max lenght 16'
65W at 12v is 5.41A (x2= 11A ), max lenght 14'
75W at 12v is 6.25A (x2= 12.5A), max lenght 12'
85W at 12v is 7.08A (x2= 14.2A), max length 10'
My lightforce lamps are 75W so I will try and keep the furthest away spot lamp at no longer than 12' long piece of wire from the battery box/relay.. If that isn't possible I would have to look at either adding more wires or lowering the Wattage of the bulbs.
Glyn Sheep
Post #52480 11th Jan 2011 11:31pm
mse
G4 they used the warn and then the other kit that name escapes for the roof. Mike
Post #52488 11th Jan 2011 11:39pm
chiefstoker
Mr. Green Ok Ok calm down ay ay .. I'm new to this game thanks dan
Post #52493 12th Jan 2011 12:16am
mse
And im not MR should do a search Thumbs Up Rolling with laughter Mike
Post #52497 12th Jan 2011 12:36am
chiefstoker
'Mind Reader' yeah? Laughing
Post #52629 12th Jan 2011 10:31pm
mse
If you look on other threads (maybe do a search Thud ) then you will see another estalished forum member likes suggesting it Whistle hence Mr. Do a search Mike
Post #52653 12th Jan 2011 11:36pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Sorry to start this off again..... Would this kit be any good for wiring up 2 170 lightforce lights...I think they are 100w
http://www.demon-tweeks.co.uk/Motorsport/L...5/0/106284 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #53927 19th Jan 2011 6:02pm
mse
My word with those kits...its a good kit but its not very flexible and its expensive for what it is.
I had 4 of those kits (free) i just used them over time for parts.
My 220watt lights they werent up to it BTW Mike
Post #53930 19th Jan 2011 6:13pm
